Old 23-01-2011, 06:00 PM   #1 (permalink)
mohityadavx's Avatar
Unhappy USB TRouble !!!
Hi!
I Am suffering a strange problem. I am having a portable 1TB 3.5" external seagate freeagent hard drive. It was running all right but all of a sudden now when i plug it my computer doesn't show it. Although the option to safely remove freeagent comes as soon as i plug it. I could even remove it safely. My usb drives are working properly and i have checked them by inserting other pen drive . Plz Plz help me out guys I have a lot of important data on it.
I am using windows 7 ultimate.
My system config is as follows:
Core2Duo E7400 @ 2.8 Ghz
2 X 2gb Kingston 800Mhz RAM
NVIDIA 8400 GS
SEAGATE 250 GB HDD
INTEL CHIPSET (don't remeber the model no)
Looking 4 help!
mohityadavx is offline   Reply With Quote
Old 23-01-2011, 06:08 PM   #2 (permalink)
Never give up!!
jerrin_ss5's Avatar
Default Re: USB TRouble !!!
try connecting to different ports!!
if the problem persists try it on another PC!!
if again problem persists we'll have to see !!!
AMD Phenom-II X4-810:| || Zotac 8200 A-E :sad:||OCZ PC2 6400 -2GB + 1GB (platinum + gold edition ):-) || Segate 250GB & WD green 500GB :||| ZOTAC GTX 460 1Gb DDR5 :grin:|| Cooler Master GX550W Bronze:||| AOC 2236VW:grin:.
jerrin_ss5 is offline   Reply With Quote
Old 23-01-2011, 06:09 PM   #3 (permalink)
The Sorcerer's Avatar
Keep it connected and check in the bios if the system can detect the drive. If yes, just check in control panel-> adminstrative tools-> computer management-> disk management. If the drive says unallocated, format the drive.
Hardware BBQ
The Sorcerer is online now   Reply With Quote
Old 24-01-2011, 01:25 PM   #4 (permalink)
Tried in different ports didn't work out. Plz don't tell me to format it contain about 400gb data.
Old 24-01-2011, 03:45 PM   #5 (permalink)
After plugging in the device. Go to
device manager (In run type
"devmgmt.msc") In Device
manager go to "Universal serial bus
controllers" It should list the storage
devices that you have connected
to your PC. Right click and then click
"Uninstall. Remove the USB drive
and restart your system.
Try connecting the device again, i
think this should solve the problem.
Old 25-01-2011, 06:38 PM   #6 (permalink)
Talking Re: USB TRouble !!!
Thanx All!
I figured out the issue frm ur help. Actually it was showing hdd in manage option. I marked it active and assigned it a letter. Stupid win7 wasn't assigning it a drive letter & therefore wasn't showing it either.
- by kool
- by ax3
