Old 23-01-2011, 09:23 AM   #1 (permalink)
detoknight's Avatar
Default Over Heating after upgrading to amd ccc 10.12 beta
I use an ATI radeonHD 5850
Untill yesterday, I was using ati ccc 10.9. My idle temp @ 40% fan speed would be 38 degree celcius.
After i installed AMD ccc 10.12 beta, under the same fan speed and the same settings the ideal temp is at 50.
I am pretty sure it is bcause of the new driver. (i have not done any changes in hardware or software other than install amd ccc beta)
What do i do
detoknight is offline   Reply With Quote
Old 23-01-2011, 10:40 AM   #2 (permalink)
Default Re: Over Heating after upgrading to amd ccc 10.12 beta
clean cabinet
install old drivers
use software like speed fan,open hardware monitor and put results wid screenshot here
Old 23-01-2011, 11:40 AM   #3 (permalink)
Super Moderator
asingh's Avatar
It is the driver. Try 11.1, is good.
asingh is offline   Reply With Quote
Old 23-01-2011, 12:49 PM   #4 (permalink)
detoknight's Avatar
I am not able to find a direct download link from amd. I also saw the release notes & it does not seem to do anything for 5xxxx series but only boosts performance for 6xxxx series.
I am downloading it anyway (from an external link) & let you know the results.
Old 23-01-2011, 12:58 PM   #5 (permalink)
detoknight's Avatar
Originally Posted by thetechfreak View Post
clean cabinet
install old drivers
The cabinet is very clean
I have attached the screen shot of the new catalyst control center (10.12)
you can see that the fan is at 40% speed & the temp is at 50 c (i am not running any graphic intensive app at all- it is at idle state).
In 10.9 it used to be around 38c ( only increased when i run games)
Morover , i dont want to switch to the old ccc. I like the new preset features and hotkeys for them. They are very useful for changing fan speed, clock settings, etc with just pressing hotkeys.
Old 23-01-2011, 04:39 PM   #6 (permalink)
maybe 50 percent for new driver is less than what was 50 for old driver
Old 23-01-2011, 06:20 PM   #7 (permalink)
detoknight's Avatar
No, both use the same ATI overdrive.
Morover, i can tell by the noise the fan is making. ( i always change fan speeds when i play games)
Any way i have uninstalled it and returned to my old driver
The temp returned to normal
I have attached the screenshot(one with the reinstalled old driver)
I have decided to wait, till a more stable version is released. 10.12 is still in beta and its coming out on 26th.
I was finally able to finish the last level in BFBC 2 with the new driver.
There was a bug with the old one, where the game crashed on the last level.
I am happy now.
Old 23-01-2011, 11:49 PM   #8 (permalink)
"maybe" the new driver increased the graphics card core voltage so the increase in temperature but usually this needs a bios update.
Old 23-01-2011, 11:58 PM   #9 (permalink)
Super Moderator
asingh's Avatar
Probably not changed the core voltage. Just that the temperature vs. fan speed ratios are different in driver releases.
- by kool
- by ax3
