Old 23-01-2011, 08:36 AM   #1 (permalink)
Unhappy Laptop problem
i have a acer 5745..when ever i boot it tells that checking file system on c:.while checking it hangs and doesnt go to windows.n sometimes shows that segment 265865 is unreadable.if i skip it then it goes in windows 7.i tired to format it win 7 disk many times.but after formating the laptop works fine for 1st few times.then it becomes very slow.
arijit_ad is offline   Reply With Quote
Old 23-01-2011, 10:13 AM   #2 (permalink)
geek........
Gauravs90's Avatar
Default Re: Laptop problem
It may be due to bad sectors in disk. try scanning them
Gauravs90 is offline   Reply With Quote
Old 24-01-2011, 04:56 AM   #3 (permalink)
Fast 'N' Furious
topgear's Avatar
obviously this prob is related with bad sectors.
Send it for RMA if the laptop is still under warranty but if not open up your laptop and find out the manufacturer of the HDD inside - download disk checking/scanning tool from the HDd manufacturers website and try fixing the HDD.
ToPsPeEeD = FaSt BuT StEaDy
Old 24-01-2011, 07:09 AM   #4 (permalink)
i went to service center and they tld that its software problem and they wont repair it...in service center they are telling me to prove that its having bad sectors..what to do nw?
Old 24-01-2011, 12:00 PM   #5 (permalink)
Super Moderator
asingh's Avatar
Check using this.
If you get any errors take a print out and go to the RMA station. Also keep HD Tune installed on the desktop, so you can run it there.
asingh is offline   Reply With Quote
Old 25-01-2011, 04:44 AM   #6 (permalink)
Fast 'N' Furious
topgear's Avatar
^^ that's a great idea - by using that app he can find the model and manufacturer of the HDD and if bad sectors are low in numbers he can try fixing those by downloading appropriate softwares from HDd manufactures website.
Old 25-01-2011, 03:40 PM   #7 (permalink)
if all fails,consumer court is with you
Old 26-01-2011, 08:55 AM   #8 (permalink)
thanks every1..
it came up with a new problem..its not entering into win 7..n when i tried to format it its showing No drives were found.click load driver to provide a mass storage driver for installation.so i cnt install that software.what next?
Old 27-01-2011, 05:53 AM   #9 (permalink)
Fast 'N' Furious
topgear's Avatar
Send it for RMA and tell those guys to install win7 in front of you ( don't forget to take the win 7 OS install DVD with you ).
Old 28-01-2011, 10:45 AM   #10 (permalink)
d3p
"Official HD 7970 Owner"
d3p's Avatar
Don't take a pirated copy of win 7 to acer service centre in order to install. They just need a reason to escape from their work.
Sapphire HD 7970 Unboxing
i7 2600k|Ma IV Ex-Z|Venomous X RT - CM R4's Push Pull|16GB RipjawX|Sapphire HD7970 OC, PhysX - Palit SP GTX570|OCZ Vertex 3 120GB|WD Black Raid 0, 40GB[Lisa]|AX850w|Asus Xonar DX, VK278Q|HAF 932|NZXT Sentry II| Logitech G27 Racing Wheel, G15, Attack II-HandBrake, HD C310|Razer DA|Bose Over Ear HP|Powershot HX40IS||E7-00|
IRC Krow
d3p is offline   Reply With Quote
- by kool
- by ax3
