Old 20-01-2011, 06:35 PM   #1 (permalink)
jatt's Avatar
Question Help me here
Hi frnds,
here is very strange problem that's why i came back here need serious help from all of you friends.
System info: p 4 processor 2.66 and AMI 915 motherboard,512MB RAM DDR,Hardisk(not can tell exactly)
Problem:I changed Motherboard first because its time was not saved in bios problem i think will recover when change motherboard,then on new above motherboard same problem arise again,it was ok but serious prob came out when last sunday,it starts giving massage "NTLDR missing"
then i tried to repair hardisk which was 500GB,it got corrupted now.
then i replaced hardisk with 80GB and system was ok,Till Today it was working fine,now at this time again its giving same"NTLDR missing"
now i am shocked that hardisk even dead,
Now what can i do with this system please suggest here.
ਨੋ ਗਰਲ ਫਰੈਂਡ ਨੋ ਟੈਂਨਸ਼ਨ,no girlfriend no tension,website: Punjabi.c-o.in,forum: punjabiteacher.co.cc
jatt is offline   Reply With Quote
Old 20-01-2011, 07:14 PM   #2 (permalink)
Default Re: Help me here
virus + bad PSU maybe the cause.
Old 20-01-2011, 10:44 PM   #3 (permalink)
Wise Old Ghoul
Piyush's Avatar
which OS?
if its XP then look below
1. Load Windows XP CD into CD drive.
2. Make sure BIOS is set to boot to CD drive.
3. Boot the computer from CD.
4. At menu, press "R" to load Recovery Console.
5. Select the installation to be fixed.
*The following instructions assume CD-ROM is labeled as drive D and the hard drive partition the windows installation is on is labeled as drive C. Replace the letters accordingly.
6. Type "COPY D:\i386\ntldr C:\" and press ENTER.
7. Type "COPY D:\i386\ntdetect.com C:\" and press ENTER.
8. Remove CD and type "EXIT" and press ENTER (to reboot your computer).
NOTE:the above steps are taken from other source
and they worked when the steps are properly executed
Steam:http://steamcommunity.com/id/alien007
"What kind of tomorrow should I dream about tonight"
--Get Backers
Piyush is offline   Reply With Quote
Old 21-01-2011, 12:02 AM   #4 (permalink)
XLr8
arpanmukherjee1's Avatar
faulty PSU. change it immediately.
if not, it will spell death to ram, proccy and others
arpanmukherjee1 is offline   Reply With Quote
Old 21-01-2011, 08:13 AM   #5 (permalink)
jatt's Avatar
Thanks a lot for reply here,but all of solutions i already used,
1)Already replaced PSU(no solution found)
2)Recovery console used(No Solution)
3)Replaced RAM and ATX too (this was first solution i done but no success)
Now what can i do that Purchase a new one,But i want reason behind it?????
Old 21-01-2011, 07:52 PM   #6 (permalink)
XLr8
your problem occurs only for faulty PSU or HDD with lots of bad sectors.
if PSU is already faulty. no point in replacing HDD until u buy another PSU
Old 22-01-2011, 02:48 PM   #7 (permalink)
put xp install cd,select repair option then type fix boot and en ter..after confirn message reboot
Old 28-01-2011, 01:18 PM   #8 (permalink)
d3p
"Official HD 7970 Owner"
d3p's Avatar
If possible then go for a clean installations of Xp & get a good antivirus like Mcafee or Nod32 then scan the HDD too.
Sapphire HD 7970 Unboxing
i7 2600k|Ma IV Ex-Z|Venomous X RT - CM R4's Push Pull|16GB RipjawX|Sapphire HD7970 OC, PhysX - Palit SP GTX570|OCZ Vertex 3 120GB|WD Black Raid 0, 40GB[Lisa]|AX850w|Asus Xonar DX, VK278Q|HAF 932|NZXT Sentry II| Logitech G27 Racing Wheel, G15, Attack II-HandBrake, HD C310|Razer DA|Bose Over Ear HP|Powershot HX40IS||E7-00|
IRC Krow
d3p is offline   Reply With Quote
- by kool
- by ax3
