Old 19-01-2011, 11:19 PM   #1 (permalink)
Red face Need suggestion on using SATA HDD on 845gv mobo as primary
Hello All,
Am new to this forum , while searching for some information about hardware I found his forum.
My 40 gb hdd stopped working, now am in confusion whether to buy a new IDE HDD 80GB which is around 2250 or buy a SATA 250 GB and use it with the help of PCI sata adapter.
Also If I buy SATA HDD then I can use it in future when I upgrade my PC. But my doubt is will SATA HDD works fine as PRIMARY from which system has to boot ??
Processor is celeron 2.4
Motherboard is intel chipset 845gv
Ram 512 mb
Can I go for SATA HDD with PCI SATA adapter and using this as my primary harddisk to boot the system ?
Please provide your suggestions ASAP
Thanks,
Openkiddo
openkiddo is offline   Reply With Quote
Old 20-01-2011, 07:47 AM   #2 (permalink)
Default Re: Need suggestion on using SATA HDD on 845gv mobo as primary
Don't count on the boot part. A quick Google tells about many people facing problems.
Keep your IDE HDD as the boot drive and go for a PCI-SATA adapter + SATA HDD. But I see your current IDE HDD has stopped working.
Old 20-01-2011, 11:19 AM   #3 (permalink)
XLr8
arpanmukherjee1's Avatar
pci boot device is not a good option .
IMO buy LGA775 mobo with DDR2 1 GB ram
else buy another IDE hd
arpanmukherjee1 is offline   Reply With Quote
Old 21-01-2011, 05:41 AM   #4 (permalink)
Fast 'N' Furious
topgear's Avatar
Buying a another IDE HDD seems to be the best option for him.
@ OP - Where did you get the price quote of Rs. 2250 for 80GB IDE Hdd ?
160GB IDE HDD costs around ~2.1k and 250GB is around ~3k.
ToPsPeEeD = FaSt BuT StEaDy
Old 21-01-2011, 01:04 PM   #5 (permalink)
That would also translate into a new processor purchase. He has a socket 478 processor, I think.
Old 24-01-2011, 11:31 PM   #6 (permalink)
Thankyou all for your suggestions.
Ok ,I will buy IDE HDD 160 GB.Am planning to buy seagate 160 GB in SP road/bangalore to let me know if anyboby knows a dealer who gives for best price. Seagate 160 gb should be fine ?
-openkiddo
- by kool
- by ax3
