Hi There
I've made this PC 1.8 years ago with ur help
Now I'm back for upgrade suggestions
My Config:
Q8200 @ 2.8 Ghz, GA-EP45C-DS3R, Palit HD4850, WD 1TB Black, 2x2GB 5-5-5-15 800(1:1) Mhz Kingston, Vx2235wm-5 (2ms, C.R 1000(typ), DVI),Creative 5.1, Corsair Vx450W
In at my place (delhi) rates are as:-
source:
http://www.costtocost.in/list/pricelist.pdf
RAM
DDR3 CORSAIR 4GB(1333): Rs. 2000
DDR2-2GB simmtronics: Rs.1262
Now Since I already have DDR2 4GB & want to upgrade to 8GB
Shall I go for DDR2 or 3?
and what speed?
HDD:
additional 1TB WD green (Rs. 2500) or Blue (???) just want to increase capacity.
Grafix
Though not actively considering it will Finding & buying another Palit HD4850 will be better or replacing with better card, considering adding another Gx Card will tax PSU?
Just checked the
memory support list for my board
and for some reason it did not have 4GB memory module for DDR3 ?
but initially it was given that I can go upto 8GB in DDR3.
So is it that My selection is already made and have to go with ddr2?
Will the above mentioned simmtronics memory will work good with already installed kingston?
