Old 12-01-2011, 10:39 PM   #1 (permalink)
Default Lan light going on and off !!!
Watch the problem on youtube
My lan connection keeps going on and off with mtnl router ..
When router is connected to my laptop .. Internet works
flawlessly ...
All this happened after I installed ubuntu 10.10 ...
There the lan was not working so I did some mischief in the
settings ...
After still no results I restarted my machine in windows ...
And found this problem ...
Even after I deleted ubuntu, the problem persists ...
I tried Re installing from motherboard cd still no effect ...
I let windows install the drivers still the problem is there ...
I fear my onboard lan has gone kaput ..
What do I do I`m panicing guys plz help ....
vizkid2005 is offline   Reply With Quote
Old 13-01-2011, 07:41 AM   #2 (permalink)
paroh's Avatar
Default Re: Lan light going on and off !!!
Try to run the network card at 10Mbps
Further check how to do it
http://www.home-network-help.com/speed-and-duplex.html
***********For computer related Problem PM me (If want's Doeacc A Level Project PM Me )************
paroh is offline   Reply With Quote
Old 15-01-2011, 05:58 PM   #3 (permalink)
it means there is transfer of data
Old 15-01-2011, 06:33 PM   #4 (permalink)
see the video..
Win hardware worth 11k!!
rajan1311 is offline   Reply With Quote
- by kool
- by ax3
