Audio failure on a few games - very strange
I am having a strange problem when playing a few games - when the game is running, sound randomly disappears completely. This is system wide ie no sound anywhere after that. Only a system restart fixes this. LoTR online is the one suffering from this the most.
I thought my 1 year old drivers were the problem, so I updated them. It fixed the problem partially, but it is still appearing within a few minutes of starting the game.
I re-installed the games just in case, but to no avail. All sound disappears from the system minutes after the game begins. I have also run the Win XP troubleshooter but no problems listed in it showed up. The device is working properly and there are no hardware conflicts as far as I can tell.
Please help me fix this. I am posting the results of Dxdiag here; if any further information is needed, please ask me
In case it matters, my PC will sometimes just lock up and only pressing the 'Reset' button restarts it. This happens once or twice a week but I don't see any pattern to it.
System specs in my sig.
EDIT: Win XP Pro (SP3)
Realtek high def audio
System Information
Time of this report: 1/11/2011, 19:50:08
Machine name: WWW-76EBA3EA23C
Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 3 (2600.xpsp.080413-2111)
Language: English (Regional Setting: English)
System Manufacturer: INTEL_
System Model: WBIBX10J
BIOS: Default System BIOS
Processor: Intel(R) Core(TM) i5 CPU 750 @ 2.67GHz (4 CPUs)
Memory: 3318MB RAM
Page File: 651MB used, 4550MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.5512 32bit Unicode
DxDiag Notes
DirectX Files Tab: No problems found.
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Music Tab: No problems found.
Input Tab: No problems found.
Network Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: NVIDIA GeForce GTS 250
Manufacturer: NVIDIA
Chip type: GeForce GTS 250
DAC type: Integrated RAMDAC
Device Key: Enum\PCI\VEN_10DE&DEV_0615&SUBSYS_26001682&REV_A2
Display Memory: 512.0 MB
Current Mode: 1440 x 900 (32 bit) (60Hz)
Monitor: Plug and Play Monitor
Monitor Max Res: 1600,1200
Driver Name: nv4_disp.dll
Driver Version: 6.14.0012.6099 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 10/22/2010 11:53:22, 6359552 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: n/a
VDD: n/a
Mini VDD: nv4_mini.sys
Mini VDD Date: 10/22/2010 11:53:22, 9623680 bytes
Device Identifier: {D7B71E3E-4555-11CF-E162-0C0603C2CB35}
Vendor ID: 0x10DE
Device ID: 0x0615
SubSys ID: 0x26001682
Revision ID: 0x00A2
Revision ID: 0x00A2
Video Accel: ModeMPEG2_C ModeMPEG2_D
Deinterlace Caps: {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
DDraw Test Result: Not run
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run
Sound Devices
Description: Realtek HD Audio output
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0888&SUBSYS_80860034&REV_1002
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: RtkHDAud.sys
Driver Version: 5.10.0000.6201 (English)
WHQL Logo'd: Yes
Date and Size: 9/14/2010 18:00:32, 6143592 bytes
Other Files:
Driver Provider: Realtek Semiconductor Corp.
HW Accel Level: Full
Cap Flags: 0xF5F
Min/Max Sample Rate: 8000, 192000
Static/Strm HW Mix Bufs: 33, 31
Static/Strm HW 3D Bufs: 33, 31
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: Yes, Yes
I3DL2(tm) Listen/Src: Yes, Yes
Sensaura(tm) ZoomFX(tm): No
Registry: OK
Sound Test Result: Not run
Sound Capture Devices
Description: Realtek HD Audio Input
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x41
Format Flags: 0xFFF
DirectMusic
DLS Path: C:\WINDOWS\SYSTEM32\drivers\GM.DLS
DLS Version: 1.00.0016.0002
Acceleration: n/a
Ports: Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal, Default Port
Microsoft MIDI Mapper [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
Microsoft GS Wavetable SW Synth [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
Registry: OK
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Device Name: USB Keyboard
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x04D9, 0x1603
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Poll w/ Interrupt: No
Registry: OK
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x8086, 0x3B34
| Matching Device ID: usb\root_hub20
| Service: usbhub
| Driver: usbhub.sys, 4/14/2008 18:45:38, 59520 bytes
| Driver: usbd.sys, 8/23/2001 02:30:00, 4736 bytes
+-+ Generic USB Hub
| | Vendor/Product ID: 0x8087, 0x0020
| | Matching Device ID: usb\class_09
| | Service: usbhub
Gameport Devices
PS/2 Devices
+ HID Keyboard Device
| Matching Device ID: hid_device_system_keyboard
| Service: kbdhid
| Driver: kbdhid.sys, 4/14/2008 10:39:50, 14592 bytes
| Driver: kbdclass.sys, 4/14/2008 10:39:48, 24576 bytes
+ Terminal Server Keyboard Driver
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
| Driver: termdd.sys, 4/15/2008 00:13:22, 40840 bytes
+ HID-compliant mouse
| Vendor/Product ID: 0x04F3, 0x0212
| Matching Device ID: hid_device_system_mouse
| Service: mouhid
| Driver: mouclass.sys, 4/23/2008 20:06:41, 23040 bytes
| Driver: mouhid.sys, 4/23/2008 20:05:45, 12160 bytes
+ Terminal Server Mouse Driver
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
DirectPlay Service Providers
DirectPlay8 Modem Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.5512)
DirectPlay8 Serial Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.5512)
DirectPlay8 IPX Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.5512)
DirectPlay8 TCP/IP Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.5512)
Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.5512)
IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.5512)
Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.5512)
Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.5512)
DirectPlay Voice Wizard Tests: Full Duplex: Not run, Half Duplex: Not run, Mic: Not run
DirectPlay Test Result: Not run
Registry: OK
DirectPlay Adapters
DirectPlay8 TCP/IP Service Provider: Local Area Connection - IPv4 -
DirectPlay Voice Codecs
Voxware VR12 1.4kbit/s
Voxware SC06 6.4kbit/s
Voxware SC03 3.2kbit/s
MS-PCM 64 kbit/s
MS-ADPCM 32.8 kbit/s
Microsoft GSM 6.10 13 kbit/s
TrueSpeech(TM) 8.6 kbit/s
DirectPlay Lobbyable Apps
Age of Empires II (DX7) - Registry: OK, ExeFile: Empires2.Exe (0.14.0014.0914)
Age of Empires II - The Conquerors Expansion (DX7) - Registry: OK, ExeFile: \age2_x1.exe (0.07.0022.0627)
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 7.7 GB
Total Space: 100.0 GB
File System: NTFS
Model: ST3500418AS
Drive: D:
Free Space: 15.3 GB
Total Space: 32.8 GB
File System: FAT32
Model: ST3160215AS
Drive: E:
Free Space: 20.3 GB
Total Space: 200.0 GB
File System: NTFS
Model: ST3500418AS
Drive: F:
Free Space: 5.7 GB
Total Space: 176.9 GB
File System: NTFS
Model: ST3500418AS
Drive: H:
Free Space: 43.5 GB
Total Space: 119.9 GB
File System: NTFS
Model: ST3160215AS
Drive: I:
Free Space: 7.9 GB
Total Space: 41.0 GB
File System: NTFS
Model: ST380817AS
Drive: J:
Free Space: 5.2 GB
Total Space: 12.0 GB
File System: NTFS
Model: ST380817AS
Drive: K:
Free Space: 8.2 GB
Total Space: 10.0 GB
File System: NTFS
Model: ST380817AS
Drive: M:
Model: SONY DVD RW AD-7240S
Driver: c:\windows\system32\drivers\cdrom.sys, 5.01.2600.5512 (English), 4/14/2008 10:40:48, 62976 bytes
Drive: N:
Model: NATEHKN LQV45A349 SCSI CdRom Device
System Devices
Name: Intel(R) processor Miscellaneous Registers - D158
Device ID: PCI\VEN_8086&DEV_D158&SUBSYS_00000000&REV_11\3&B1BFB68&0&43
Driver: n/a
Name: Intel(R) processor System Control and Status Registers - D157
Device ID: PCI\VEN_8086&DEV_D157&SUBSYS_00000000&REV_11\3&B1BFB68&0&42
Driver: n/a
Name: Intel(R) processor Semaphore and Scratchpad Registers - D156
Device ID: PCI\VEN_8086&DEV_D156&SUBSYS_00000000&REV_11\3&B1BFB68&0&41
Driver: n/a
Name: Intel(R) processor System Management Registers - D155
Device ID: PCI\VEN_8086&DEV_D155&SUBSYS_00000000&REV_11\3&B1BFB68&0&40
Driver: n/a
Name: Intel(R) QuickPath Interconnect - D151
Device ID: PCI\VEN_8086&DEV_D151&SUBSYS_00000000&REV_11\3&B1BFB68&0&81
Driver: n/a
Name: Intel(R) QuickPath Interconnect - D150
Device ID: PCI\VEN_8086&DEV_D150&SUBSYS_00000000&REV_11\3&B1BFB68&0&80
Driver: n/a
Name: Intel(R) processor PCI Express Root Port 1 - D138
Device ID: PCI\VEN_8086&DEV_D138&SUBSYS_00000000&REV_11\3&B1BFB68&0&18
Driver: C:\WINDOWS\system32\DRIVERS\pci.sys, 5.01.2600.5512 (English), 4/14/2008 18:36:46, 68224 bytes
Name: Intel(R) processor DMI - D131
Device ID: PCI\VEN_8086&DEV_D131&SUBSYS_00000000&REV_11\3&B1BFB68&0&00
Driver: n/a
Name: Microsoft UAA Bus Driver for High Definition Audio
Device ID: PCI\VEN_8086&DEV_3B56&SUBSYS_00348086&REV_05\3&B1BFB68&0&D8
Driver: C:\WINDOWS\system32\DRIVERS\hdaudbus.sys, 5.10.0001.5013 (English), 4/14/2008 08:36:06, 144384 bytes
Name: Intel(R) 5 Series/3400 Series Chipset Family PCI Express Root Port 7 - 3B4E
Device ID: PCI\VEN_8086&DEV_3B4E&SUBSYS_00000000&REV_05\3&B1BFB68&0&E6
Name: Intel(R) 5 Series/3400 Series Chipset Family PCI Express Root Port 5 - 3B4A
Device ID: PCI\VEN_8086&DEV_3B4A&SUBSYS_00000000&REV_05\3&B1BFB68&0&E4
Name: Intel(R) 5 Series/3400 Series Chipset Family PCI Express Root Port 1 - 3B42
Device ID: PCI\VEN_8086&DEV_3B42&SUBSYS_00000000&REV_05\3&B1BFB68&0&E0
Name: Intel(R) 5 Series/3400 Series Chipset Family USB Enhanced Host Controller - 3B3C
Device ID: PCI\VEN_8086&DEV_3B3C&SUBSYS_42578086&REV_05\3&B1BFB68&0&D0
Driver: C:\WINDOWS\system32\drivers\usbehci.sys, 5.01.2600.5512 (English), 4/14/2008 18:45:36, 30208 bytes
Driver: C:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.5512 (English), 4/14/2008 18:45:38, 143872 bytes
Driver: C:\WINDOWS\system32\usbui.dll, 5.01.2600.5512 (English), 4/15/2008 00:12:10, 74240 bytes
Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.5512 (English), 4/14/2008 18:45:38, 59520 bytes
Driver: C:\WINDOWS\system32\hccoin.dll, 5.01.2600.5512 (English), 4/14/2008 16:11:56, 7168 bytes
Name: Intel(R) 5 Series/3400 Series Chipset Family USB Enhanced Host Controller - 3B34
Device ID: PCI\VEN_8086&DEV_3B34&SUBSYS_42578086&REV_05\3&B1BFB68&0&E8
Name: Intel(R) 5 Series/3400 Series Chipset Family SMBus Controller - 3B30
Device ID: PCI\VEN_8086&DEV_3B30&SUBSYS_42578086&REV_05\3&B1BFB68&0&FB
Driver: n/a
Name: Intel(R) 5 Series/3400 Series Chipset Family 2 port Serial ATA Storage Controller - 3B26
Device ID: PCI\VEN_8086&DEV_3B26&SUBSYS_42578086&REV_05\3&B1BFB68&0&FD
Driver: C:\WINDOWS\system32\DRIVERS\pciide.sys, 5.01.2600.0000 (English), 8/18/2001 08:21:52, 3328 bytes
Driver: C:\WINDOWS\system32\DRIVERS\pciidex.sys, 5.01.2600.5512 (English), 4/14/2008 18:40:30, 24960 bytes
Driver: C:\WINDOWS\system32\DRIVERS\atapi.sys, 5.01.2600.5512 (English), 4/14/2008 18:40:32, 96512 bytes
Name: Intel(R) 5 Series/3400 Series Chipset Family 4 port Serial ATA Storage Controller - 3B20
Device ID: PCI\VEN_8086&DEV_3B20&SUBSYS_42578086&REV_05\3&B1BFB68&0&FA
Name: Intel(R) P55 Express Chipset LPC Interface Controller - 3B02
Device ID: PCI\VEN_8086&DEV_3B02&SUBSYS_00000000&REV_05\3&B1BFB68&0&F8
Driver: C:\WINDOWS\system32\DRIVERS\isapnp.sys, 5.01.2600.5512 (English), 4/14/2008 18:36:42, 37248 bytes
Name: Intel(R) 82801 PCI Bridge - 244E
Device ID: PCI\VEN_8086&DEV_244E&SUBSYS_00000000&REV_A5\3&B1BFB68&0&F0
Name: Intel(R) 82578DC Gigabit Network Connection
Device ID: PCI\VEN_8086&DEV_10F0&SUBSYS_00008086&REV_05\3&B1BFB68&0&C8
Driver: C:\WINDOWS\system32\DRIVERS\e1k5132.sys, 11.08.0075.0000 (English), 9/29/2010 12:10:22, 173736 bytes
Driver: C:\WINDOWS\system32\e1k5132.din, 10/9/2009 10:43:54, 3187 bytes
Driver: C:\WINDOWS\system32\NicCo2.dll, 1.02.0000.0000 (English), 8/7/2007 06:58:34, 28272 bytes
Driver: C:\WINDOWS\system32\NicInstK.dll, 9.10.0041.0000 (English), 4/13/2010 23:47:46, 74944 bytes
Driver: C:\WINDOWS\system32\e1kmsg.dll, 10.00.0059.0000 (English), 4/1/2010 23:56:24, 68264 bytes
Name: NVIDIA GeForce GTS 250
Device ID: PCI\VEN_10DE&DEV_0615&SUBSYS_26001682&REV_A2\4&6795F8C&0&0018
Driver: C:\Program Files\NVIDIA Corporation\Drs\dbInstaller.exe, 6.14.0012.6099 (English), 10/22/2010 11:53:22, 145408 bytes
Driver: C:\Program Files\NVIDIA Corporation\Drs\nvdrsdb.bin, 10/22/2010 11:53:29, 240592 bytes
Driver: C:\Program Files\NVIDIA Corporation\license.txt, 10/22/2010 11:53:22, 15511 bytes
Driver: C:\WINDOWS\system32\DRIVERS\nv4_mini.sys, 6.14.0012.6099 (English), 10/22/2010 11:53:22, 9623680 bytes
Driver: C:\WINDOWS\system32\OpenCL.dll, 1.00.0000.0000 (English), 10/22/2010 11:53:30, 61440 bytes
Driver: C:\WINDOWS\system32\nv4_disp.dll, 6.14.0012.6099 (English), 10/22/2010 11:53:22, 6359552 bytes
Driver: C:\WINDOWS\system32\nvapi.dll, 6.14.0012.6099 (English), 10/22/2010 11:53:22, 1462272 bytes
Driver: C:\WINDOWS\system32\nvcompiler.dll, 6.14.0012.6099 (English), 10/22/2010 11:53:22, 13012992 bytes
Driver: C:\WINDOWS\system32\nvcuda.dll, 6.14.0012.6099 (English), 10/22/2010 11:53:29, 4882432 bytes
Driver: C:\WINDOWS\system32\nvcuvenc.dll, 6.14.0012.6099 (English), 10/22/2010 11:53:29, 2666600 bytes
Driver: C:\WINDOWS\system32\nvcuvid.dll, 6.14.0012.6099 (English), 10/22/2010 11:53:29, 2932840 bytes
Driver: C:\WINDOWS\system32\nvdata.bin, 10/22/2010 11:53:29, 2293194 bytes
Driver: C:\WINDOWS\system32\nvinfo.pb, 10/22/2010 11:53:29, 3739 bytes
Driver: C:\WINDOWS\system32\nvoglnt.dll, 6.14.0012.6099 (English), 10/22/2010 11:53:30, 14532608 bytes
Driver: C:\WINDOWS\system32\nvdispco32.dll, 2.00.0005.0000 (English), 10/22/2010 11:53:29, 888424 bytes
Driver: C:\WINDOWS\system32\nvgenco32.dll, 2.00.0003.0000 (English), 10/22/2010 11:53:29, 813672 bytes
Name: Texas Instruments OHCI Compliant IEEE 1394 Host Controller
Device ID: PCI\VEN_104C&DEV_8023&SUBSYS_42578086&REV_00\4&1F8E6776&0&18F0
Driver: C:\WINDOWS\system32\DRIVERS\ohci1394.sys, 5.01.2600.5512 (English), 4/14/2008 10:46:20, 61696 bytes
Driver: C:\WINDOWS\system32\DRIVERS\1394bus.sys, 5.01.2600.5512 (English), 4/14/2008 10:46:20, 53376 bytes
Driver: C:\WINDOWS\system32\DRIVERS\nic1394.sys, 5.01.2600.5512 (English), 4/23/2008 20:06:41, 61824 bytes
Driver: C:\WINDOWS\system32\DRIVERS\arp1394.sys, 5.01.2600.5512 (English), 4/23/2008 20:06:41, 60800 bytes
Driver: C:\WINDOWS\system32\DRIVERS\enum1394.sys, 5.01.2600.0000 (English), 8/18/2001 00:16:40, 6400 bytes
DirectX Components
ddraw.dll: 5.03.2600.5512 English Final Retail 4/14/2008 16:11:52 279552 bytes
ddrawex.dll: 5.03.2600.5512 English Final Retail 4/14/2008 16:11:52 27136 bytes
dxapi.sys: 5.01.2600.0000 English Final Retail 8/23/2001 02:30:00 10496 bytes
d3d8.dll: 5.03.2600.5512 English Final Retail 4/14/2008 16:11:52 1179648 bytes
d3d8thk.dll: 5.03.2600.5512 English Final Retail 4/14/2008 16:11:52 8192 bytes
d3d9.dll: 5.03.2600.5512 English Final Retail 4/14/2008 16:11:52 1689088 bytes
d3dim.dll: 5.01.2600.0000 English Final Retail 8/23/2001 02:30:00 436224 bytes
d3dim700.dll: 5.03.2600.5512 English Final Retail 4/14/2008 16:11:52 824320 bytes
d3dramp.dll: 5.01.2600.0000 English Final Retail 8/23/2001 02:30:00 590336 bytes
d3drm.dll: 5.01.2600.0000 English Final Retail 8/23/2001 02:30:00 350208 bytes
d3dxof.dll: 5.01.2600.0000 English Final Retail 8/23/2001 02:30:00 47616 bytes
d3dpmesh.dll: 5.01.2600.0000 English Final Retail 8/23/2001 02:30:00 34816 bytes
dplay.dll: 5.00.2134.0001 English Final Retail 8/23/2001 02:30:00 33040 bytes
dplayx.dll: 5.03.2600.5512 English Final Retail 4/14/2008 16:11:54 229888 bytes
dpmodemx.dll: 5.03.2600.5512 English Final Retail 4/14/2008 16:11:54 23552 bytes
dpwsock.dll: 5.00.2134.0001 English Final Retail 8/23/2001 02:30:00 42768 bytes
dpwsockx.dll: 5.03.2600.5512 English Final Retail 4/14/2008 16:11:54 57344 bytes
dplaysvr.exe: 5.03.2600.5512 English Final Retail 4/14/2008 16:12:18 29696 bytes
dpnsvr.exe: 5.03.2600.5512 English Final Retail 4/14/2008 16:12:18 17920 bytes
dpnet.dll: 5.03.2600.5512 English Final Retail 4/14/2008 16:11:54 375296 bytes
dpnlobby.dll: 5.03.2600.5512 English Final Retail 4/14/2008 16:09:22 3072 bytes
dpnaddr.dll: 5.03.2600.5512 English Final Retail 4/14/2008 16:09:20 3072 bytes
dpvoice.dll: 5.03.2600.5512 English Final Retail 4/14/2008 16:11:54 212480 bytes
dpvsetup.exe: 5.03.2600.5512 English Final Retail 4/14/2008 16:12:20 83456 bytes
dpvvox.dll: 5.03.2600.5512 English Final Retail 4/14/2008 16:11:54 116736 bytes
dpvacm.dll: 5.03.2600.5512 English Final Retail 4/14/2008 16:11:54 21504 bytes
dpnhpast.dll: 5.03.2600.5512 English Final Retail 4/14/2008 16:11:54 35328 bytes
dpnhupnp.dll: 5.03.2600.5512 English Final Retail 4/14/2008 16:11:54 60928 bytes
dpserial.dll: 5.00.2134.0001 English Final Retail 8/23/2001 02:30:00 53520 bytes
dinput.dll: 5.03.2600.5512 English Final Retail 4/14/2008 16:11:54 158720 bytes
dinput8.dll: 5.03.2600.5512 English Final Retail 4/14/2008 16:11:54 181760 bytes
dimap.dll: 5.01.2600.0000 English Final Retail 8/23/2001 02:30:00 44032 bytes
diactfrm.dll: 5.01.2600.0000 English Final Retail 8/23/2001 02:30:00 394240 bytes
joy.cpl: 5.03.2600.5512 English Final Retail 4/14/2008 16:12:42 68608 bytes
gcdef.dll: 5.01.2600.0000 English Final Retail 8/23/2001 02:30:00 76800 bytes
pid.dll: 5.03.2600.5512 English Final Retail 4/23/2008 20:06:41 35328 bytes
dsound.dll: 5.03.2600.5512 English Final Retail 4/14/2008 16:11:54 367616 bytes
dsound3d.dll: 5.03.2600.5512 English Final Retail 4/14/2008 16:11:54 1293824 bytes
dswave.dll: 5.03.2600.5512 English Final Retail 4/14/2008 16:11:54 19456 bytes
dsdmo.dll: 5.03.2600.5512 English Final Retail 4/14/2008 16:11:54 181248 bytes
dsdmoprp.dll: 5.03.2600.5512 English Final Retail 4/14/2008 16:11:54 71680 bytes
dmusic.dll: 5.03.2600.5512 English Final Retail 4/14/2008 16:11:54 104448 bytes
dmband.dll: 5.03.2600.5512 English Final Retail 4/14/2008 16:11:54 28672 bytes
dmcompos.dll: 5.03.2600.5512 English Final Retail 4/14/2008 16:11:54 61440 bytes
dmime.dll: 5.03.2600.5512 English Final Retail 4/14/2008 16:11:54 181248 bytes
dmloader.dll: 5.03.2600.5512 English Final Retail 4/14/2008 16:11:54 35840 bytes
dmstyle.dll: 5.03.2600.5512 English Final Retail 4/14/2008 16:11:54 105984 bytes
dmsynth.dll: 5.03.2600.5512 English Final Retail 4/14/2008 16:11:54 103424 bytes
dmscript.dll: 5.03.2600.5512 English Final Retail 4/14/2008 16:11:54 82432 bytes
system.dll: 1.01.4322.2407 English Final Retail 12/25/2009 10:14:25 1232896 bytes
Microsoft.DirectX.Direct3D.dll: 9.05.0132.0000 English Final Retail 12/27/2010 13:13:31 473600 bytes
Microsoft.DirectX.Direct3DX.dll: 5.04.0000.3900 English Final Retail 12/27/2010 13:13:26 2676224 bytes
Microsoft.DirectX.Direct3DX.dll: 9.04.0091.0000 English Final Retail 12/27/2010 13:13:27 2846720 bytes
Microsoft.DirectX.Direct3DX.dll: 9.05.0132.0000 English Final Retail 12/27/2010 13:13:27 563712 bytes
Microsoft.DirectX.Direct3DX.dll: 9.06.0168.0000 English Final Retail 12/27/2010 13:13:28 567296 bytes
Microsoft.DirectX.Direct3DX.dll: 9.07.0239.0000 English Final Retail 12/27/2010 13:13:28 576000 bytes
Microsoft.DirectX.Direct3DX.dll: 9.08.0299.0000 English Final Retail 12/27/2010 13:13:29 577024 bytes
Microsoft.DirectX.Direct3DX.dll: 9.09.0376.0000 English Final Retail 12/27/2010 13:13:29 577536 bytes
Microsoft.DirectX.Direct3DX.dll: 9.10.0455.0000 English Final Retail 12/27/2010 13:13:29 577536 bytes
Microsoft.DirectX.Direct3DX.dll: 9.11.0519.0000 English Final Retail 12/27/2010 13:13:30 578560 bytes
Microsoft.DirectX.Direct3DX.dll: 9.12.0589.0000 English Final Retail 12/27/2010 13:13:31 578560 bytes
Microsoft.DirectX.DirectDraw.dll: 5.04.0000.2904 English Final Retail 12/27/2010 13:13:31 145920 bytes
Microsoft.DirectX.DirectInput.dll: 5.04.0000.2904 English Final Retail 12/27/2010 13:13:31 159232 bytes
Microsoft.DirectX.DirectPlay.dll: 5.04.0000.2904 English Final Retail 12/27/2010 13:13:32 364544 bytes
Microsoft.DirectX.DirectSound.dll: 5.04.0000.2904 English Final Retail 12/27/2010 13:13:32 178176 bytes
Microsoft.DirectX.AudioVideoPlayback.dll: 5.04.0000.2904 English Final Retail 12/27/2010 13:13:30 53248 bytes
Microsoft.DirectX.Diagnostics.dll: 5.04.0000.2904 English Final Retail 12/27/2010 13:13:31 12800 bytes
Microsoft.DirectX.dll: 5.04.0000.2904 English Final Retail 12/27/2010 13:13:30 223232 bytes
dx7vb.dll: 5.03.2600.5512 English Final Retail 4/14/2008 16:11:54 619008 bytes
dx8vb.dll: 5.03.2600.5512 English Final Retail 4/14/2008 16:11:54 1227264 bytes
dxdiagn.dll: 5.03.2600.5512 English Final Retail 4/14/2008 16:11:54 2113536 bytes
mfc40.dll: 4.01.0000.6140 English Final Retail 8/23/2001 02:30:00 924432 bytes
mfc42.dll: 6.02.4131.0000 English Final Retail 4/14/2008 16:11:58 1028096 bytes
wsock32.dll: 5.01.2600.5512 English Final Retail 4/14/2008 16:12:12 22528 bytes
amstream.dll: 6.05.2600.5512 English Final Retail 4/14/2008 16:11:50 70656 bytes
devenum.dll: 6.05.2600.5512 English Final Retail 4/14/2008 16:11:52 59904 bytes
dxmasf.dll: 6.04.0009.1133 English Final Retail 4/14/2008 16:11:54 498742 bytes
mciqtz32.dll: 6.05.2600.5512 English Final Retail 4/14/2008 16:11:58 35328 bytes
mpg2splt.ax: 6.05.2600.5512 English Final Retail 4/14/2008 16:12:44 148992 bytes
msdmo.dll: 6.05.2600.5512 English Final Retail 4/14/2008 16:12:00 14336 bytes
encapi.dll: 5.03.2600.5512 English Final Retail 4/14/2008 16:11:54 20480 bytes
qasf.dll: 9.00.0000.4503 English Final Retail 4/14/2008 16:12:04 237568 bytes
qcap.dll: 6.05.2600.5512 English Final Retail 4/14/2008 16:12:04 192512 bytes
qdv.dll: 6.05.2600.5512 English Final Retail 4/14/2008 16:12:04 279040 bytes
qdvd.dll: 6.05.2600.5512 English Final Retail 4/14/2008 16:12:04 386048 bytes
qedit.dll: 6.05.2600.5512 English Final Retail 4/14/2008 16:12:04 562176 bytes
qedwipes.dll: 6.05.2600.5512 English Final Retail 4/14/2008 09:21:34 733696 bytes
quartz.dll: 6.05.2600.5512 English Final Retail 4/14/2008 16:12:04 1288192 bytes
strmdll.dll: 4.01.0000.3936 English Final Retail 4/14/2008 16:12:08 246814 bytes
iac25_32.ax: 2.00.0005.0053 English Final Retail 4/14/2008 16:12:44 199680 bytes
ir41_32.ax: 4.51.0016.0003 English Final Retail 4/14/2008 16:12:44 848384 bytes
ir41_qc.dll: 4.30.0062.0002 English Final Retail 4/14/2008 16:11:56 120320 bytes
ir41_qcx.dll: 4.30.0064.0001 English Final Retail 4/14/2008 16:11:56 338432 bytes
ir50_32.dll: 5.2562.0015.0055 English Final Retail 4/14/2008 16:11:56 755200 bytes
ir50_qc.dll: 5.00.0063.0048 English Final Retail 4/14/2008 16:11:56 200192 bytes
ir50_qcx.dll: 5.00.0064.0048 English Final Retail 4/14/2008 16:11:56 183808 bytes
ivfsrc.ax: 5.10.0002.0051 English Final Retail 4/14/2008 16:12:44 154624 bytes
mswebdvd.dll: 6.05.2600.5512 English Final Retail 4/14/2008 16:12:02 203776 bytes
ks.sys: 5.03.2600.5512 English Final Retail 4/14/2008 05:46:38 141056 bytes
ksproxy.ax: 5.03.2600.5512 English Final Retail 4/14/2008 10:42:44 129536 bytes
ksuser.dll: 5.03.2600.5512 English Final Retail 4/14/2008 10:41:58 4096 bytes
stream.sys: 5.03.2600.5512 English Final Retail 4/14/2008 05:15:16 49408 bytes
mspclock.sys: 5.03.2600.5512 English Final Retail 4/14/2008 18:39:52 5376 bytes
mspqm.sys: 5.01.2600.5512 English Final Retail 4/14/2008 18:39:52 4992 bytes
mskssrv.sys: 5.03.2600.5512 English Final Retail 4/14/2008 18:39:54 7552 bytes
swenum.sys: 5.03.2600.5512 English Final Retail 4/23/2008 20:06:41 4352 bytes
mpeg2data.ax: 6.05.2600.5512 English Final Retail 4/14/2008 16:12:44 118272 bytes
msvidctl.dll: 6.05.2600.5512 English Final Retail 4/14/2008 16:12:02 1428992 bytes
vbisurf.ax: 5.03.2600.5512 English Final Retail 4/14/2008 16:12:44 30208 bytes
msyuv.dll: 5.03.2600.5512 English Final Retail 4/23/2008 20:06:41 16896 bytes
wstdecod.dll: 5.03.2600.5512 English Final Retail 4/14/2008 16:12:12 50688 bytes
DirectShow Filters
DirectShow Filters:
QuickTime Audio Decoder Filter,0x00600800,1,1,,
WMAudio Decoder DMO,0x00800800,1,1,,
WMSpeech Decoder DMO,0x00600800,1,1,,
WMVideo 8 Decoder DMO,0x00800001,1,1,,
Mpeg4s Decoder DMO,0x00800001,1,1,,
WMV Screen decoder DMO,0x00800001,1,1,,
WMVideo Decoder DMO,0x00800001,1,1,,
QuickTime Video Decoder Filter,0x00600800,1,1,,
Mpeg43 Decoder DMO,0x00800001,1,1,,
Mpeg4 Decoder DMO,0x00800001,1,1,,
ffdshow Video Decoder,0xff800001,2,1,ffdshow.ax,1.01.3361.0000
Full Screen Renderer,0x00200000,1,0,quartz.dll,6.05.2600.5512
Gretech ASF Source Filter,0x00200000,0,1,GSFU.ax,
CoreVorbis Audio Decoder,0x00800000,1,1,CoreVorbis.ax,1.01.0000.0079
ffdshow DXVA Video Decoder,0xff800002,2,1,ffdshow.ax,1.01.3361.0000
ffdshow raw video filter,0x00200000,2,1,ffdshow.ax,1.01.3361.0000
Gretech MPEG Source Filter,0x00200000,0,1,GSFU.ax,
Nero Scene Detector 2,0x00200000,2,0,NeSceneDetector.ax,3.02.0000.0020
ffdshow Audio Decoder,0xff800001,1,1,ffdshow.ax,1.01.3361.0000
DV Muxer,0x00400000,0,0,qdv.dll,6.05.2600.5512
MPC - Mpeg Source (Gabest),0x00400000,0,0,MpegSplitter.ax,1.03.1774.0000
Nero Digital Audio Decoder,0x00600000,1,1,NeAudio.ax,3.02.0000.0020
Color Space Converter,0x00400001,1,1,quartz.dll,6.05.2600.5512
WM ASF Reader,0x00400000,0,0,qasf.dll,9.00.0000.4503
AVI Splitter,0x00600000,1,1,quartz.dll,6.05.2600.5512
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.05.2600.5512
Indeo® video 5.10 Compression Filter,0x00200000,1,1,ir50_32.dll,5.2562.0015.0055
Windows Media Audio Decoder,0x00800001,1,1,msadds32.ax,8.00.0000.4487
RealVideo Decoder,0x00400000,1,1,RealMediaSplitter.ax,1.00.0001.0001
MONOGRAM AMR Splitter,0x00600000,1,1,mmamr.ax,1.00.0001.0000
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.05.2600.5512
StreamBufferSink,0x00200000,0,0,sbe.dll,6.05.2600.5512
Nero Resize,0x00200000,1,1,NeResize.ax,3.02.0000.0020
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.5512
Indeo® video 5.10 Decompression Filter,0x00640000,1,1,ir50_32.dll,5.2562.0015.0055
Microsoft Screen Video Decompressor,0x00800000,1,1,msscds32.ax,8.00.0000.4487
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.05.2600.5512
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.05.2600.5512
MPEG Layer-3 Decoder,0x00810000,1,1,l3codecx.ax,1.05.0000.0050
Nero Audio Stream Renderer,0x00200000,1,0,NeRender.ax,3.02.0000.0020
MPV Decoder Filter,0x40000002,1,1,Mpeg2DecFilter.ax,1.00.0000.0003
CyberLink Video/SP Decoder (PDVD9),0x003f0001,2,3,CLVSD.ax,8.04.0000.1014
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.05.2600.5512
MPC - MP4 Source,0x00600000,0,0,MP4Splitter.ax,1.03.1774.0000
ACELP.net Sipro Lab Audio Decoder,0x00800001,1,1,acelpdec.ax,1.04.0000.0000
Gretech Video Filter,0x00200000,1,1,GVF.ax,
Nero Digital AVC Audio Encoder,0x00200000,1,2,NeNDAud.ax,3.02.0000.0020
Nero Digital AVC File Writer,0x00200000,1,0,NeNDMux.ax,3.02.0000.0020
Nero Digital AVC Null Renderer,0x00200000,1,0,NeNDMux.ax,3.02.0000.0020
Nero Digital AVC Muxer,0x00200000,2,1,NeNDMux.ax,3.02.0000.0020
Nero Digital AVC Video Enc,0x00200000,1,2,,
Canon MDP Motion-JPEG Decoder,0x00200001,1,1,CanonMDPMJPEGDecoder.ax,2.05.0000.0005
DivX MKV Demux (unrestricted),0x00200000,0,1,DMFSource.ax,1.00.0002.0006
Canon Motion-JPEG Encoder,0x00200000,1,1,CanonMJPEGEncoder.ax,3.02.0000.0004
Nero QuickTime(tm) Video Decoder,0x00400000,1,1,NeQTDec.ax,3.02.0000.0020
MPC - FLV Splitter (Gabest),0x00600000,1,1,FLVSplitter.ax,1.03.1774.0000
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.05.2600.5512
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.05.2600.5512
Gretech OGG2 Source Filter,0x00200000,0,1,GSFU.ax,
WavPack Audio Decoder,0x00600000,1,1,WavPackDSDecoder.ax,1.01.0000.0484
File Source (Netshow URL),0x00400000,0,1,wmpasf.dll,9.00.0000.4503
FLV File Source,0x00200000,0,2,Flv.ax,2006.02.0028.0001
Nero Format Converter,0x00200000,1,1,NeroFormatConv.ax,3.02.0000.0020
Gretech FLV Source Filter,0x00200000,0,1,GSFU.ax,
Canon Mov File Parser Filter,0x00600001,1,1,CanonH264Filter.ax,1.03.0001.0015
DV Splitter,0x00600000,1,2,qdv.dll,6.05.2600.5512
Windows Media Video Decoder,0x00800000,1,1,wmvds32.ax,8.00.0000.4487
MONOGRAM AMR Decoder,0x00600000,1,1,mmamr.ax,1.00.0001.0000
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.05.2600.5512
Windows Media Video Decoder,0x00800000,1,1,wmv8ds32.ax,8.00.0000.4000
Nero Photo Source,0x00200000,0,1,NePhotoSource.ax,3.02.0000.0020
MONOGRAM Musepack Decoder,0x00600000,1,1,mmmpcdec.ax,0.09.0002.0000
Haali Media Splitter,0x00800001,0,1,splitter.ax,1.10.0120.0015
Haali Media Splitter (AR),0x00400000,1,1,splitter.ax,1.10.0120.0015
Nero Video Analyzer,0x00200000,2,0,NeVideoAnalyzer.ax,3.02.0000.0020
Gretech AsfEx Source Filter,0x00200000,0,1,GSFU.ax,
Nero ES Video Reader,0x00600000,0,1,NDParser.ax,3.02.0000.0020
MPC - MP4 Splitter,0x00600000,1,1,MP4Splitter.ax,1.03.1774.0000
Nero Audio CD Filter,0x00200000,0,1,NeAudCD.ax,3.02.0000.0020
Windows Media Multiplexer,0x00600000,1,1,wmpasf.dll,9.00.0000.4503
ASX file Parser,0x00600000,1,1,wmpasf.dll,9.00.0000.4503
ASX v.2 file Parser,0x00600000,1,0,wmpasf.dll,9.00.0000.4503
NSC file Parser,0x00600000,1,1,wmpasf.dll,9.00.0000.4503
File Source (Monkey Audio),0x00400000,0,1,MonkeySource.ax,
MainConcept (Nikon) MPEG Audio Decoder,0x00400000,1,1,nikondsmpeg.ax,1.00.0000.0076
MainConcept (Nikon) MPEG Video Decoder,0x00400000,1,1,nikondsmpeg.ax,1.00.0000.0076
MainConcept (Nikon) MPEG Encoder,0x00200000,2,1,nikonesmpeg.ax,1.01.0000.0026
ACM Wrapper,0x00600000,1,1,quartz.dll,6.05.2600.5512
CoreAAC Audio Decoder,0x00800000,1,1,CoreAAC.ax,1.01.0000.0643
madFlac Decoder,0x00600000,1,1,madFlac.ax,1.08.0000.0000
Windows Media source filter,0x00600000,0,2,wmpasf.dll,9.00.0000.4503
Gretech AVI Source Filter,0x00200000,0,1,GSFU.ax,
Video Renderer,0x00800001,1,0,quartz.dll,6.05.2600.5512
Gretech Network(OGG) Filter,0x00200000,0,1,GNF.ax,
Nero DVD Navigator,0x00600000,0,4,NeDVD.ax,3.02.0000.0020
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.05.2600.5512
Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.05.2600.5512
Video Port Manager,0x00600000,2,1,quartz.dll,6.05.2600.5512
DivX H.264 Decoder,0x00800000,1,1,DivXDecH264.ax,9.00.0001.0021
WST Decoder,0x00600000,1,1,wstdecod.dll,5.03.2600.5512
Video Renderer,0x00400000,1,0,quartz.dll,6.05.2600.5512
Microsoft MPEG-4 Video Decompressor,0x00800000,1,1,mp4sds32.ax,8.00.0000.0344
Haali Video Renderer,0x00200000,1,0,dxr.dll,
RealMedia Source,0x00600000,0,0,RealMediaSplitter.ax,1.00.0001.0001
Nero Audio Sample Renderer,0x00200000,1,0,NeRender.ax,3.02.0000.0020
Nero Vcd Navigator,0x00600000,0,2,NeVcd.ax,3.02.0000.0020
DivX Decoder Filter,0x00800000,1,1,DivXDec.ax,7.01.0001.0014
Nero Audio Processor,0x00200000,1,1,NeAudioConv.ax,3.02.0000.0020
WM ASF Writer,0x00400000,0,0,qasf.dll,9.00.0000.4503
Gretech Audio Filter,0x00200000,1,1,GAF.ax,
Nero Mpeg2 Encoder,0x00200000,2,1,NeVCR.ax,3.02.0000.0020
Canon Custom Resizer SaveMode,0x00200000,1,1,CanonDESResizer.ax,3.02.0000.0009
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,5.03.2600.5512
Canon Text Source Filter,0x00200000,0,1,CanonTextSourceFilter.ax,3.02.0000.0013
Microsoft MPEG-4 Video Decompressor,0x00800000,1,1,mpg4ds32.ax,8.00.0000.4487
Nero Video Stream Renderer,0x00200000,1,0,NeRender.ax,3.02.0000.0020
File writer,0x00200000,1,0,qcap.dll,6.05.2600.5512
Canon Image Rotation Filter,0x00200000,1,1,CanonRotateFilter.dll,1.05.0001.0018
Gretech Network(FLV) Filter,0x00200000,0,1,GNF.ax,
Gretech OGG Source Filter,0x00200000,0,1,GSFU.ax,
Gretech Network(AVI) Filter,0x00200000,0,1,GNF.ax,
Canon Motion-JPEG Decoder,0x00200001,1,1,CanonMJPEGDecoder.ax,3.02.0000.0006
Nero PS Muxer,0x00200000,1,1,NePSMuxer.ax,3.02.0000.0020
Haali Simple Media Splitter,0x00200000,0,1,splitter.ax,1.10.0120.0015
DirectVobSub,0x00200000,2,1,vsfilter.dll,2.39.0005.0003
RealAudio Decoder,0x00400000,1,1,RealMediaSplitter.ax,1.00.0001.0001
Gretech MKV Source Filter,0x00200000,0,1,GSFU.ax,
DirectVobSub (auto-loading version),0x00800002,2,1,vsfilter.dll,2.39.0005.0003
MONOGRAM AMR Encoder,0x00600000,1,1,mmamr.ax,1.00.0001.0000
DVD Navigator,0x00200000,0,2,qdvd.dll,6.05.2600.5512
Overlay Mixer2,0x00400000,1,1,qdvd.dll,6.05.2600.5512
Haali Matroska Muxer,0x00200000,1,0,splitter.ax,1.10.0120.0015
Nero Splitter,0x00600000,1,3,NeSplitter.ax,3.02.0000.0020
DivX MKV Demux,0x00600000,0,1,DMFSource.ax,1.00.0002.0006
AC3Filter,0x40000000,1,1,ac3filter.cpl,1.00.0001.0000
AVI Draw,0x00600064,9,1,quartz.dll,6.05.2600.5512
.RAM file Parser,0x00600000,1,0,wmpasf.dll,9.00.0000.4503
muvee Music Analyser,0x00200000,1,0,mvmanalyse.ax,4.00.0022.0003
MONOGRAM AMR Mux,0x00600000,1,1,mmamr.ax,1.00.0001.0000
Nero File Source / Splitter,0x00600000,0,3,NeFSource.ax,3.02.0000.0020
DC-Bass Source,0x00400000,0,1,DCBassSource.ax,1.02.0000.0000
G.711 Codec,0x00200000,1,1,g711codc.ax,5.01.2600.0000
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.05.2600.5512
DV Video Decoder,0x00800000,1,1,qdv.dll,6.05.2600.5512
Canon Actual Data Length Setter,0x00200000,1,1,CanonActualDataLengthSetter.ax,3.02.0000.0005
Indeo® audio software,0x00500000,1,1,iac25_32.ax,2.00.0005.0053
Windows Media Update Filter,0x00400000,1,0,wmpasf.dll,9.00.0000.4503
Canon H.264 Decode Filter 1.3,0x00600001,1,1,CanonH264Filter.ax,1.03.0001.0015
Gretech Network(SHOUTcast) Filter,0x00200000,0,1,GNF.ax,
ffdshow Audio Processor,0x00200000,1,1,ffdshow.ax,1.01.3361.0000
ASF DIB Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.4503
ASF ACM Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.4503
ASF ICM Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.4503
ASF URL Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.4503
ASF JPEG Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.4503
ASF DJPEG Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.4503
ASF embedded stuff Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.4503
WIA Stream Snapshot Filter,0x00200000,1,1,wiasf.ax,1.00.0000.0000
Nero Video Processor,0x00200000,1,1,NeroVideoProc.ax,3.02.0000.0020
QuickTime Source Filter,0x00200000,0,1,QuickTimeSource.dll,4.00.0046.0004
Gretech Network(GOM) Filter,0x00200000,0,1,GNF.ax,
Nero Video Decoder,0x00600000,2,2,NeVideo.ax,3.02.0000.0020
SampleGrabber,0x00200000,1,1,qedit.dll,6.05.2600.5512
Null Renderer,0x00200000,1,0,qedit.dll,6.05.2600.5512
VP7 Decompressor,0x00800000,1,1,vp7dec.ax,7.00.0010.0000
MONOGRAM Musepack Splitter,0x00600000,1,1,mmmpcdmx.ax,0.04.0000.0000
madFlac Source,0x00600000,0,1,madFlac.ax,1.08.0000.0000
Nero Audio CD Navigator,0x00200000,0,1,NeAudCD.ax,3.02.0000.0020
Gretech MP3 Source Filter,0x00200000,0,1,GSFU.ax,
Canon H.264 Encoder 1.1,0x00200001,1,1,CanonH264Encoder.ax,1.01.0000.0018
MPC - FLV Source (Gabest),0x00600000,0,0,FLVSplitter.ax,1.03.1774.0000
StreamBufferSource,0x00200000,0,0,sbe.dll,6.05.2600.5512
Smart Tee,0x00200000,1,2,qcap.dll,6.05.2600.5512
Overlay Mixer,0x00200000,0,0,qdvd.dll,6.05.2600.5512
Nero Scene Detector,0x00200000,1,0,NeSceneDetector.ax,3.02.0000.0020
RealPlayer Audio Filter,0x00200000,1,1,rdsf3260.dll,6.00.0012.0933
AVI Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.5512
Canon Resizer,0x00200000,1,1,CanonResizer.ax,3.02.0000.0006
Gretech MP4 Source Filter,0x00200000,0,1,GSFU.ax,
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.05.2600.5512
MPC - MPEG4 Video Splitter,0x00600000,1,1,MP4Splitter.ax,1.03.1774.0000
QuickTime Movie Parser,0x00600000,1,1,quartz.dll,6.05.2600.5512
Wave Parser,0x00400000,1,1,quartz.dll,6.05.2600.5512
MIDI Parser,0x00400000,1,1,quartz.dll,6.05.2600.5512
Multi-file Parser,0x00400000,1,1,quartz.dll,6.05.2600.5512
File stream renderer,0x00400000,1,1,quartz.dll,6.05.2600.5512
XML Playlist,0x00400000,1,0,wmpasf.dll,9.00.0000.4503
Canon WAV Dest,0x00200000,0,0,CanonWavDest.ax,3.02.0000.0004
Nero File Source,0x00200000,0,1,NeFileSrc.ax,3.02.0000.0020
Nero QuickTime(tm) Audio Decoder,0x00400000,1,1,NeQTDec.ax,3.02.0000.0020
WavPack Audio Splitter,0x00600000,1,1,WavPackDSSplitter.ax,1.01.0000.0323
Nero File Source (Async.),0x00400000,0,1,NeFileSourceAsync.ax,3.02.0000.0020
ffdshow subtitles filter,0x00200000,2,1,ffdshow.ax,1.01.3361.0000
MPC - Mpeg Splitter (Gabest),0x00400001,1,1,MpegSplitter.ax,1.03.1774.0000
Nero DVD Decoder,0x00600000,2,2,NeVideo.ax,3.02.0000.0020
Nero Digital Parser,0x00600000,0,3,NDParser.ax,3.02.0000.0020
RealMedia Splitter,0x00600000,1,1,RealMediaSplitter.ax,1.00.0001.0001
AVI Mux,0x00200000,1,0,qcap.dll,6.05.2600.5512
MPC - MPEG4 Video Source,0x00600000,0,0,MP4Splitter.ax,1.03.1774.0000
muvee WAV Encoder,0x00200000,0,0,mvWavEnc.ax,9.00.0000.0000
CyberLink QuickTime Source Filter,0x00200000,0,2,QuickTime.ax,1.00.0000.1016
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.05.2600.5512
File Source (Async.),0x00400000,0,1,quartz.dll,6.05.2600.5512
File Source (URL),0x00400000,0,1,quartz.dll,6.05.2600.5512
Nero Frame Capture,0x00200000,1,1,NeCapture.ax,3.02.0000.0020
Nero Video Sample Renderer,0x00200000,1,0,NeRender.ax,3.02.0000.0020
Haali Video Sink,0x00200000,1,0,splitter.ax,1.10.0120.0015
AC3File,0x00600000,0,1,ac3file.ax,
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.05.2600.5512
Nero DV Splitter,0x00200000,1,2,NeDVSplitter.ax,3.02.0000.0020
QT Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.5512
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.05.2600.5512
psWav Dest,0x00200000,0,0,psWavDes.ax,1.01.0000.0002
Indeo® video 4.4 Decompression Filter,0x00640000,1,1,ir41_32.ax,4.51.0016.0003
Indeo® video 4.4 Compression Filter,0x00200000,1,1,ir41_32.ax,4.51.0016.0003
WDM Streaming Data Transforms:
Microsoft Kernel Acoustic Echo Canceller,0x00000000,0,0,,
Microsoft Kernel GS Wavetable Synthesizer,0x00200000,1,1,,5.03.2600.5512
Microsoft Kernel DLS Synthesizer,0x00200000,1,1,,5.03.2600.5512
Microsoft Kernel DRM Audio Descrambler,0x00200000,1,1,,5.03.2600.5512
Video Compressors:
MSScreen encoder DMO,0x00600800,1,1,,
WMVideo9 Encoder DMO,0x00600800,1,1,,
MSScreen 9 encoder DMO,0x00600800,1,1,,
DV Video Encoder,0x00200000,0,0,qdv.dll,6.05.2600.5512
ffdshow video encoder,0x00100000,1,1,ffdshow.ax,1.01.3361.0000
Indeo® video 5.10 Compression Filter,0x00100000,1,1,ir50_32.dll,5.2562.0015.0055
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.05.2600.5512
Nero Digital AVC Video Enc,0x00200000,1,2,NeNDVid.ax,3.02.0000.0020
Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.05.2600.5512
DivX 6.9.2 Codec (4 Logical CPUs),0x00200000,1,1,qcap.dll,6.05.2600.5512
ffdshow Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.5512
Fraps Video Decompressor,0x00200000,1,1,qcap.dll,6.05.2600.5512
Intel 4:2:0 Video V2.50,0x00200000,1,1,qcap.dll,6.05.2600.5512
Intel Indeo(R) Video R3.2,0x00200000,1,1,qcap.dll,6.05.2600.5512
Intel Indeo® Video 4.5,0x00200000,1,1,qcap.dll,6.05.2600.5512
Indeo® video 5.10,0x00200000,1,1,qcap.dll,6.05.2600.5512
Intel IYUV codec,0x00200000,1,1,qcap.dll,6.05.2600.5512
Microsoft MPEG-4 Video Codec V2,0x00200000,1,1,qcap.dll,6.05.2600.5512
Microsoft MPEG-4 Video Codec V1,0x00200000,1,1,qcap.dll,6.05.2600.5512
Microsoft RLE,0x00200000,1,1,qcap.dll,6.05.2600.5512
Microsoft Video 1,0x00200000,1,1,qcap.dll,6.05.2600.5512
Xvid MPEG-4 Codec,0x00200000,1,1,qcap.dll,6.05.2600.5512
DivX 6.9.2 YV12 Decoder,0x00200000,1,1,qcap.dll,6.05.2600.5512
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,,
WMAudio Encoder DMO,0x00600800,1,1,,
IAC2,0x00200000,1,1,quartz.dll,6.05.2600.5512
IMA ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.5512
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.5512
ACELP.net,0x00200000,1,1,quartz.dll,6.05.2600.5512
DSP Group TrueSpeech(TM),0x00200000,1,1,quartz.dll,6.05.2600.5512
Windows Media Audio V1,0x00200000,1,1,quartz.dll,6.05.2600.5512
Windows Media Audio V2,0x00200000,1,1,quartz.dll,6.05.2600.5512
GSM 6.10,0x00200000,1,1,quartz.dll,6.05.2600.5512
CCITT A-Law,0x00200000,1,1,quartz.dll,6.05.2600.5512
CCITT u-Law,0x00200000,1,1,quartz.dll,6.05.2600.5512
AC-3 ACM Codec,0x00200000,1,1,quartz.dll,6.05.2600.5512
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.05.2600.5512
Audio Capture Sources:
Realtek HD Audio Input,0x00200000,0,0,qcap.dll,6.05.2600.5512
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.05.2600.5512
Microsoft GS Wavetable SW Synth,0x00200000,1,0,quartz.dll,6.05.2600.5512
WDM Streaming Capture Devices:
Realtek HD Audio Input,0x00200000,1,1,,5.03.2600.5512
WDM Streaming Rendering Devices:
Realtek HD Audio output,0x00200000,2,1,,5.03.2600.5512
WDM Streaming Mixer Devices:
Microsoft Kernel Wave Audio Mixer,0x00000000,0,0,,
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,0,encdec.dll,6.05.2600.5512
Encrypt/Tag,0x00200000,0,0,encdec.dll,6.05.2600.5512
XDS Codec,0x00200000,0,0,encdec.dll,6.05.2600.5512
Audio Renderers:
Realtek HD Audio output,0x00200000,1,0,quartz.dll,6.05.2600.5512
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.05.2600.5512
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.05.2600.5512
DirectSound: Realtek HD Audio output,0x00200000,1,0,quartz.dll,6.05.2600.5512
WDM Streaming System Devices:
Realtek HD Audio Input,0x00200000,4,1,,5.03.2600.5512
Realtek HD Audio output,0x00200000,11,1,,5.03.2600.5512
Intel core i5 750 with DP55WB mobo
4 GGB DDR3 RAM@1333MHz Transcend
CM Extreme Power Duo 600W
XFX GTS 250 512MB
Win XP Pro 32-bit
