Old 09-01-2011, 04:35 PM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
papashango_cs's Avatar
Default Audio jack issue ! please help
hii all !
i have a ZEBRONICS BIJLI cab, Gigabyt Ga 880 MA UD2h Mothrboard,
the cabinet has a set of audio jacks in THE REAR , and two more jacks(BUT in the FRONT ), 1 AUX jack , and 1 MIC jack. i have plugged in the speakers in the rear, but if want to use headfones in the front jack as well, it doesnt work !
i even tried plugging in the speakers in the front instead of the rear , it still didnt work !
what to do ?
my hardware is fine , i have win 7 ultimate 64 bit
i have to pull out my cab everytime to switch to headfones, wich is reaLLy hard !
- thanks
Dont f^^k with me :X
amd phenom x4 945 | MSI hd6850 | 4gb d4 | zebronics BiJLi
papashango_cs is offline   Reply With Quote
Old 09-01-2011, 06:00 PM   #2 (permalink)
Super Moderator
asingh's Avatar
Default Re: Audio jack issue ! please help
Probably the audio pin headers are not connected properly. Read them as per the motherboard manual and reconnect them.
asingh is offline   Reply With Quote
Old 09-01-2011, 07:07 PM   #3 (permalink)
Ohk..thats hard foR me !
like we have a usb splitter , http://images.dealsvista.com/show?&id=31416
can i get an Audio jack spliter ?
Old 09-01-2011, 07:20 PM   #4 (permalink)
digitalpainter
digibrush's Avatar
Altai F387 Mini Jack Stereo Splitter | DV247
Intel DH55TC/Core i3 2.93Ghz/corsair Ram(4x2gb1333)/Sapphire HD5670 1Gb/Seagate 1Tb+500Gb/Seagate1TB External/CM Elite 430 & Real power Pro 460W/Creative Audigy+Inspire/iball pentablet/Razer Abyssus//Razer Goliathus/DellST2220L/Windows 7 Ultimate 64 bit.
It's good to touch the green, green grass of home.
digibrush is offline   Reply With Quote
Old 09-01-2011, 08:20 PM   #5 (permalink)
cute.bandar's Avatar
I had this problem. Fixed by changing some setting in the BIOS. if memory serves me right I had to change some setting from HDaudio to AC'97 or something.
Computer parts search Engine(for india) : http://goo.gl/Sg8Yv
cute.bandar is offline   Reply With Quote
Old 09-01-2011, 09:49 PM   #6 (permalink)
The Assassin
Cybertonic's Avatar
I had the same problem when i put my graphics card. Turned out that the audio pin header was not connected properly. If it doesn't work, switch from AC'97 to HD Audio or the reverse header on the motherboard (use only one of them at a time).
Nothing is true. Everything is permitted.
Steam : $/@$]-[ DK
http://steamcommunity.com/profiles/76561198047340352
Cybertonic is offline   Reply With Quote
Old 10-01-2011, 04:48 AM   #7 (permalink)
Fast 'N' Furious
topgear's Avatar
Originally Posted by digibrush View Post
I've bought something like this @ only Rs. 10 though it was 4 years ago anyway.
ToPsPeEeD = FaSt BuT StEaDy
Old 11-01-2011, 02:35 PM   #8 (permalink)
speedyguy's Avatar
there exist a 3.5mm splitter but in usual cases if both output ports are plugged ur frequency gets distributed, as per my experience. holds good if u have a decent amplifier for both headphones and speakers.
and this is what i have, dunno if u have a similar case or not. mine motherboard (rear) has 3 pins one each for mic, aux out and aux in. but i can tell my system via c-media configuration to take the aux-in as secondary aux-out so i can make it a 4-way surround system with two jacks. try out playing with some settings in your bios or system audio configuration. all the best.
if nothing works, some connection issue, you may want to go though your cabinet interiors. be careful. all the best.
Enjoy~!
No Pain...No Gain
speedyguy is offline   Reply With Quote
Old 11-01-2011, 07:33 PM   #9 (permalink)
thankyou ! i got this thing , 25 buggs only !
working well for me !
Old 18-01-2011, 06:43 PM   #10 (permalink)
Reverse Engineering rocks
Sid_gamer's Avatar
The splitter works good until you attach it with high powered audio systems..
In that case a single audio port is not able to supply ample power to the speakers or the device connected and may even result into frequency disturbance or the audio port getting damaged...
i7-920|DFI LanParty DK X58-T3eH6
G.Skill-1600MHz,2Gbx3|ZotacGTX260 AMP2
Seagate 1Tb|CM Silent Pro M600
AOC-2236vW-Full HD|LG DVD/RW
Altec Lansing FX3021|MX-518
Delux DLC SH-490|CorsairH70
Sid_gamer is online now   Reply With Quote
LinkBack to this Thread: http://www.thinkdigit.com/forum/hardware-q/135868-audio-jack-issue-please-help.html
Elite Cabs, Jamshedpur | Taxi Hire Jamshedpur This thread Refback 31-10-2011 11:33 AM
- by kool
- by ax3
