Old 08-01-2011, 09:54 PM   #1 (permalink)
Default Problem with Monitor
My monitor is widescreen TFT LCD. It displays all the pictures from my digicam squeezed vertically. Can anybody help?
digik is offline   Reply With Quote
Old 08-01-2011, 10:20 PM   #2 (permalink)
Don Draper is coming back
vamsi_krishna's Avatar
Default Re: Problem with Monitor
The problem is your aspect ratio. Try changing the aspect ration in your Camcoder.
I am MaxPayne. My Wife and Daughter were murdered.
vamsi_krishna is offline   Reply With Quote
Old 10-01-2011, 06:46 AM   #3 (permalink)
Cool Buddy's Avatar
What is the native resolution of the monitor? if you don't know then search on the internet using the model number
most probably you have set the wrong resolution. Try changing the resolution from display properties, settings tab in XP
Nokia 5230 :(
Canon IXUS 115 HS :)
Old 10-01-2011, 07:06 PM   #4 (permalink)
make aspect ratio 16:9
Old 10-01-2011, 08:35 PM   #5 (permalink)
A LCD monitors viewing angle is the horizontal and vertical viewing angle at which at which LCD screen is fully visible.
source:askthecomputertech.com/lcd-monitor-buying-tips.html
http://www.electrogadgets.org
sonali321 is offline   Reply With Quote
Old 15-01-2011, 08:57 PM   #6 (permalink)
Native resolution 1600x800 is not availbable in the settings of Win 7. Aspect ratio is already 16:9.
Old 16-01-2011, 09:12 AM   #7 (permalink)
^ create custom resolution from nvidia control panel
Old 16-01-2011, 08:37 PM   #8 (permalink)
Cool Buddy's Avatar
I don't think any monitor has a native resolution of 1600x800, it must be 1600x900.
Nokia 5230 :(
Old 16-01-2011, 09:17 PM   #9 (permalink)
Yes, indeed, it is 1600x900. Sorry, for the mistake.
Couldnot find 1600x900 resolution or custom resolution in ATI Radeon control panel.
Old 18-01-2011, 06:24 PM   #10 (permalink)
Reverse Engineering rocks
Sid_gamer's Avatar
If you can't change your resolution then try Uninstalling your video drivers and re-installing them...That might help...And what is the name and Model of your monitor ???
i7-920|DFI LanParty DK X58-T3eH6
G.Skill-1600MHz,2Gbx3|ZotacGTX260 AMP2
Seagate 1Tb|CM Silent Pro M600
AOC-2236vW-Full HD|LG DVD/RW
Altec Lansing FX3021|MX-518
Delux DLC SH-490|CorsairH70
Sid_gamer is online now   Reply With Quote
Old 18-01-2011, 09:29 PM   #11 (permalink)
Resolution can be changed. But, the drop down list doesnot contain the resolution 1600x900. Model of LCD is Samsung Sync Master B2030.
- by kool
- by ax3
