Re: HDD incorrect detecting
There might be problem with the Ports or the Cable(sometimes, simple dust will cause problems like this). I had this problem once, and the HDD cable was the culprit. I changed the cable and everything was back on track. Try switching HDD to other ports, if that didn't work, Try another HDD and check if it is gets detected.
And, is this HDD a primary HDD or a Secondary one?
I am MaxPayne. My Wife and Daughter were murdered.
