Old 03-01-2011, 08:11 PM   #1 (permalink)
blademast3r's Avatar
Question XBOX 360 controller compatible with PC?
Hey guys
I wanted to know if ANY xbox 360 wired controller is compatible with pc or just specific pc versions.. Im planning to buy it off ebay..
Also is Rs 1350 a good price?
blademast3r is online now   Reply With Quote
Old 04-01-2011, 07:01 AM   #2 (permalink)
Fast 'N' Furious
topgear's Avatar
Default Re: XBOX 360 controller compatible with PC?
xbox 360 wired controller is compatible with bot windows and xbox 360.
Works across Microsoft's gaming platforms. Xbox 360 Controller for Windows works with most Windows XP-based PCs and Xbox 360, delivering a consistent and universal gaming experience.
The price is also OK.
ToPsPeEeD = FaSt BuT StEaDy
Old 04-01-2011, 10:27 AM   #3 (permalink)
Fullbring
Zangetsu's Avatar
@blademast3r: yes it is & even PS3 controller.....
Old 04-01-2011, 01:40 PM   #4 (permalink)
abirthedevil's Avatar
you need drivers for xp, plug and play with windows 7 and dunno about vista(why would you be using that crappy os in the first place?) price is ok but depending on place you can buy it for 1300 from local retailers
abirthedevil is offline   Reply With Quote
Old 05-01-2011, 04:28 PM   #5 (permalink)
Originally Posted by blademast3r View Post
Hey guys
yep.. 200% compatible.. i got it a year back.. for 1.5k and its compatible with major games and also you can configfure if with software(google) to play ehat ever you need just like a mouse and keybaord.
max.4u is offline   Reply With Quote
- by kool
- by ax3
