Old 31-12-2010, 04:03 AM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
This Is Saggi Here...
Exclamation Having Problem With Asus EAH5770 CuCore
Hi Guys,
I Need Some Hepl From You All...
Am Having A BIg Problem With My Graphic Card (Asus EAH 5770 CuCore)
Am Going To Open A Games Cafe And I Alreday Got My System.
THe Problem Is That My GPU Is Getting Dead After Some Time...
Heres The Story...
First Of All I Assembled 1 Machine And Installed Windows 7 ARC Gamer Edition 32-BIT, With Some Games (Prototpye, Fifa 11, COD - Black Ops, Etc)...
But When I Started Playing Prototype For Testing Purpose It Worked For 2 Days, Then My Machine God Blurred Image In Frozen State...
It Made Me Restart Then There Was No Display...
After Doing Some Troubleshootinh I Found GPU Dead...
Then I Put My 2nd Graphic Card And Was Intalling Some More Games But Within 3-5 Hours Again The Same Problem...
Once Again My 2nd Card Was Dead...
Now I assemebled I More Machine And Inserted my 3rd Graphic Card And Now Checking It Out...
I Don't Know Why My GPU Is Getting Dead....
My System Configuration Is:
CPU : AMD Phenom X2 550 (3.1GHZ)
MB : Asus M4A87TD/USB3 (Non-IGP Board)
RAM : Corsiar XMS3 2X2GB (1600MHZ With Heatsink)
HDD : Western Digital 500GB Green Caviar
GPU : Asus EAH5770 CuCore (1GB/GDDR5)
PSU : Antec VP450 (450W)
Cabinet : Antec NSK 4482B (With 1X120MM Fan)
LCD : Asus VW227 21.5" LCD
Key + Mouse : Logitech G1 Gaming Desktop
Please Guys Give Some Quick Response, So I Can Configure The Issue...
Having 10 Machine Of The Above Config And 1 Server..
Thanks Alot Guys...
Digit Rocks..
systechsolution is offline   Reply With Quote
Old 31-12-2010, 08:53 AM   #2 (permalink)
Never give up!!
jerrin_ss5's Avatar
Default Re: Having Problem With Asus EAH5770 CuCore
hey how did u conclude that ur GPU is dead !!!
anyways did u check whther all the GPU drivers are installed properly !!!
AMD Phenom-II X4-810:| || Zotac 8200 A-E :sad:||OCZ PC2 6400 -2GB + 1GB (platinum + gold edition ):-) || Segate 250GB & WD green 500GB :||| ZOTAC GTX 460 1Gb DDR5 :grin:|| Cooler Master GX550W Bronze:||| AOC 2236VW:grin:.
jerrin_ss5 is offline   Reply With Quote
Old 31-12-2010, 08:56 AM   #3 (permalink)
Dude, I one by one replaced my component...
First With Ram Then There Was No Benefit,
Then GPU = It Works...
And I Also Putted The Dead GPU On Another machine... Then Also No Display..
I Don't Know Exactly What is the Cause....
Old 31-12-2010, 11:19 AM   #4 (permalink)
I you PSU enough to run this Card.?? i dont think so, coz it requires much power. maybe you should try out on some branded PSU like corsair or coolermaster. this maybe the main cause
AMD Athlon II X2 250 @ 3.01GHz,
ASUS M2N68-AM Plus Mobo,
3 GB DDR2 @ 800MHZ,
seagate 7200 500GB, WD Caviar 160GB
ASUS EAH5750 FORMULA
GIGABYTE SUPERB 460W PSU.
sasuke is offline   Reply With Quote
Old 31-12-2010, 11:43 AM   #5 (permalink)
The Sorcerer's Avatar
If its still barely 2-5 days old, it qualifies for a DOA where the dealer/distri will swap it for you.
Hardware BBQ
The Sorcerer is online now   Reply With Quote
Old 31-12-2010, 06:24 PM   #6 (permalink)
Did u connected the 6pin power connector on5770 each time?
mohiuddin is offline   Reply With Quote
Old 02-01-2011, 12:52 PM   #7 (permalink)
sasuke.......
Yes, The Vendor Had Told Me That This PSU Is Enough For Your Machine.... And You Would Be Able To Overclock It Also....
And Seconldy Antec Is Also A Brand...
The Sorcerer......
===========>>>>> It Has Been A Month Old Now.... So Can't Get Table Replacement....
mohiuddin......
===============>>>>>>>>> Yes I Have Connected The 6 Pin Supply...
Guys, The Third Graphic Card Is Running Without Problem Till Far....
Waiting For Its Death..... I Don't Know Why The Bull **** Graphic Card Has Gone Dead... Will Play COD: Black Ops Today On It With High Resolution And Graphic Details..... Lets See What Happen Playing More Then 5 Hours Continuously....
"""Smoker's Die Younger""""
""I Wannnaa Die Today""
Old 03-01-2011, 08:00 AM   #8 (permalink)
Adam young
sukesh1090's Avatar
I think the problem is with power supply.when you run your graphics card continuously the psu fails due to overload and may be causing problem to your graphics card.you told you have 10 system,then how many of them have failed by now?
:razz:| [AMD PhenomII 955BE 3.2GHz @ 1.25V] [CM Hyper 212EVO][Corsair carbide 400R] [Gigabyte GA 880GM-USB3] [MSI MD1GD5 R6670 @875MHz & 1150MHz] [4GB Vengeance 1600MHz] [Seasonic S12 II 520W] [LG W1943C 19"] [Seagate baracuda 1TB] [GM M6800] [LG DVD+RW]:razz:
My rifle and myself are the defenders of my country.
We are the masters of our enemy.
We are the saviors of my life.
-Rifleman's Creed
sukesh1090 is offline   Reply With Quote
Old 03-01-2011, 10:03 PM   #9 (permalink)
Yes Dude I Think So You Are Right...
Because Currently I Have Assembled 1 More Machine And Putted The 3rd Graphic Card In It And Its Working Fine....
I Will Replace The PSU Of The First PC And Then Check It Out...
Anyway Thanks Alot...
Old 04-01-2011, 01:57 AM   #10 (permalink)
Adam young
sukesh1090's Avatar
welcome brother,good luck.
-Rifleman's Creed
LinkBack to this Thread: http://www.thinkdigit.com/forum/hardware-q/135551-having-problem-asus-eah5770-cucore.html
Clix This thread Refback 30-01-2011 05:07 AM
- by kool
- by ax3
