Old 29-12-2010, 11:40 PM   #1 (permalink)
Smile System Boot Error
hi techies.........
guys, i'm facing a problem with my system durin booting.sometimes it jst stays blank with a horizontal cursor on top left corner of screen after showing up the boot page.it continues lik that for sveral minutes n then it shows hard disk read error.i checked ma sata connection to d board, and that was OK...i can't really make out where n what s d problem.........
my sys config:-dual core processor,intel GC945 Mboard, 2gb DDR2 RAM, 160Gb seagate HDD, ASUS 5670 HD 1gb graphic card.
waiting eagerly for ur help>>>>>
arun.j is offline   Reply With Quote
Old 30-12-2010, 10:47 AM   #2 (permalink)
XLr8
arpanmukherjee1's Avatar
Default Re: help me pls..
HDD contains bad sectors.
chkdsk hdd on another system and/or buy another hdd
arpanmukherjee1 is offline   Reply With Quote
Old 30-12-2010, 11:39 AM   #3 (permalink)
Super Moderator
asingh's Avatar
Also, redo all connectors again. Seems your HDD is failing.
Changed title of thread.
asingh is offline   Reply With Quote
Old 30-12-2010, 03:22 PM   #4 (permalink)
Default Re: System Boot Error
I had the same error as well
digitor is offline   Reply With Quote
Old 30-12-2010, 07:12 PM   #5 (permalink)
thank u guys for quick reply>>>>>>>
another msg dats showing up after boot is
"PXE ROM error"
"no bootable device"
"insert boot disk and try again"
does this have any connection with HDD error?
Old 30-12-2010, 10:00 PM   #6 (permalink)
^^ either HDD connection is loose or HDD's life is almost over.
suggestion: backup your important data using a 2nd HDD as boot hard drive/linux live cd (ubuntu is a good option).
Old 31-12-2010, 08:56 AM   #7 (permalink)
Never give up!!
jerrin_ss5's Avatar
i think the OS of urs has gone corrupt affecting the boot files try repairing the boot file or format ur c drive to a fresh copy of OS !!
AMD Phenom-II X4-810:| || Zotac 8200 A-E :sad:||OCZ PC2 6400 -2GB + 1GB (platinum + gold edition ):-) || Segate 250GB & WD green 500GB :||| ZOTAC GTX 460 1Gb DDR5 :grin:|| Cooler Master GX550W Bronze:||| AOC 2236VW:grin:.
jerrin_ss5 is offline   Reply With Quote
- by kool
- by ax3
