Old 29-12-2010, 06:59 PM   #1 (permalink)
KRISHI101's Avatar
Exclamation Can not Install Pendrive
Hello Friends,..
My problem is i cant install new Pen-drives..
I don't remember how the problem occur and when?
( May be when i update my window xp - Because you know the notification comes showing your computer might be at risk - Enable update. So i update it and then the problem occurred )
But whenever i insert new Pen-drive of anyone the window box appear saying Found New Hardware...
I follow the steps but it just showing busy like " wait hardware driver is installing "...
But nothing happens...
or the dialogue box comes like cant install...
Everybody knows hardware like pendrive installs automatically..
So why the box comes?
and why i cant install new pendrive..?
-While my old Pendrives running smoothly..
( pardon for my bad grammar )
KRISHI101 is offline   Reply With Quote
Old 29-12-2010, 10:08 PM   #2 (permalink)
blackhole's Avatar
Default Re: Can not Install Pendrive
i suggest backup n format windows
blackhole is offline   Reply With Quote
Old 03-01-2011, 10:44 PM   #3 (permalink)
This Is Saggi Here...
You having windows XP with latest update then the usb driver should be there...
And your pc is displaying that found new hardware... then its obvious that your usb driver is corrupt or uninstalled... first install a usb driver and then check it out... if the problem still exists then as blackhole sad that backup and format no option...
mean while check out that pen drive on any other pc... might be the pen drive also faulty...
"""Smoker's Die Younger""""
""I Wannnaa Die Today""
systechsolution is offline   Reply With Quote
Old 04-01-2011, 06:51 AM   #4 (permalink)
Fast 'N' Furious
topgear's Avatar
Uninstall all usb controller drivers from device manager. Restart windows. USB drivers will auto install or install mobo chipset drivers. Reboot again and try inserting that flash drive.
ToPsPeEeD = FaSt BuT StEaDy
Old 09-01-2011, 02:37 PM   #5 (permalink)
KRISHI101's Avatar
Thanks systechsolution..
But where i found the USB driver..
i dont want to format window..
and it happen in every new pendrive..
so now every new hardware doesnt install automatically or manually..
while old pendrive which are known by my pc..
works fine..
And topgear..
i m afraid to do ur steps..
if i unistall and if auto install fails... then it will become more big problem..
becoz old pendrive working fine usb slots..
only new pendrive is not installing...
Thanks Everyone..
but need more..
Old 09-01-2011, 06:26 PM   #6 (permalink)
XLr8
arpanmukherjee1's Avatar
updating windows xp can be really painful. had no issues with updating win7
what uninstall means is - not to delete config for pendrives but to uninstall the drivers.
or u can rollback drivers too.
steps:
1. create restore point
2. roll-back drivers
screenshot:
also, did ur mobo cd come with usb driver? try that too.
arpanmukherjee1 is offline   Reply With Quote
Old 10-01-2011, 03:51 AM   #7 (permalink)
Fast 'N' Furious
topgear's Avatar
@ KRISHI101 - try the new pen drive on a friend's pc and let us know if it's working there ?
Old 27-02-2011, 01:08 PM   #8 (permalink)
KRISHI101's Avatar
i already told you every new hardware is not installing in my pc..
only old hardware known by my pc working fine..
---------- Post added at 01:08 PM ---------- Previous post was at 01:06 PM ----------
Please read my problem full...
and i think its because of i downloaded microsoft updates..
and some security update cause this problem..
Old 28-02-2011, 07:18 AM   #9 (permalink)
Fast 'N' Furious
topgear's Avatar
OK - use system restore and restore your system to a previous date on which you have no such issue. That should roll back any changes made by windows update.
If that does not helps reinstall a fresh copy of windows.
Old 28-02-2011, 07:43 AM   #10 (permalink)
Microsoft recently published an update for XP which disables Autorun on pendrives. This update might be causing you such problems.
Try reinstalling that update again. Google for it.
pauldmps is offline   Reply With Quote
Old 03-03-2011, 10:14 AM   #11 (permalink)
KRISHI101's Avatar
Hi i m attaching my Add/Remove programs screenshot of window update..
if you can find the causing update..
But many many thanks for Every Reply...
Old 13-04-2011, 11:20 PM   #12 (permalink)
KRISHI101's Avatar
Anyone find Solution...
I still cant install any new Hardware..
Even if i have cd of it.
Dont know how to tweak it Back..
Thanks for any suggestion...
Waiting...
Old 13-04-2011, 11:31 PM   #13 (permalink)
Try restoring.If you don't have restore points (there should be one as you updated) then try repairing option after booting in via xp cd. Although you might have reinstall some software's like demon tools (if there are any such).
Abhinav
abhinav_sinha is offline   Reply With Quote
Old 14-04-2011, 07:27 AM   #14 (permalink)
Living to Play
gameranand's Avatar
@KRISHI101
Well your PC is pretty fu(ked up so I am afraid you have reinstall your windows. Try the idea of topgear because if it works then fine or either way you have to reinstall your OS.
In war, Victory. In peace, Vigilance. In death, Sacrifice.
Using TDF through mobile. Digit optimized this forum for mobiles. Works nicely YAY :D:D
gameranand is offline   Reply With Quote
- by kool
- by ax3
