Old 29-12-2010, 11:58 AM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
Smile checking if motherboard support virtualization
hello, everybody
i have got a gigabyte motherboard G31M-ES2L expresses chipset and i need help in this. i need to know if this motherboard support virtualization or not. i need to run red hat Enterprise Linux 6 x64 bit OS it.
thanks beforehand to anybody who helps....
ans wishing everybody a happy new year.....
Rituraj Goswami
Raj_Kayshap is offline   Reply With Quote
Old 29-12-2010, 12:18 PM   #2 (permalink)
Never give up!!
jerrin_ss5's Avatar
Default Re: checking if motherboard support virtualization
well i think its not the mo-bo which is responsible for virtualisation through h/w but the processor
to check whether ur processor supports virtualisation try using securable
GRC|SecurAble: Determine Processor Security Features|
AMD Phenom-II X4-810:| || Zotac 8200 A-E :sad:||OCZ PC2 6400 -2GB + 1GB (platinum + gold edition ):-) || Segate 250GB & WD green 500GB :||| ZOTAC GTX 460 1Gb DDR5 :grin:|| Cooler Master GX550W Bronze:||| AOC 2236VW:grin:.
jerrin_ss5 is offline   Reply With Quote
Old 31-12-2010, 06:13 AM   #3 (permalink)
Fast 'N' Furious
topgear's Avatar
yep VT is cpu based feature not mobo.
@ Raj_Kayshap - which cpu do you have ?
ToPsPeEeD = FaSt BuT StEaDy
LinkBack to this Thread: http://www.thinkdigit.com/forum/hardware-q/135488-checking-if-motherboard-support-virtualization.html
Thread checking if motherboard support virtualization | Digit Forum | BoardReader This thread Refback 25-07-2011 08:14 AM
- by kool
- by ax3
