29-12-2010, 11:31 AM
help system restarts up frequently...
P2 x4 955 B.e,ga880gm-usb3,corsair 6gb,tx650,sea 1tb+500*2,cm690 with 7 fans 120mm,curve 2000 and mx518,sony &hp optical drive,sunbeam cold cathode*2 & bubble lights,benq g2222hdl.samsung 32"full hd.
29-12-2010, 11:55 AM
Super Moderator
Re: help system restarts up frequently...
Post the last 5-6 memory dumps to a location, and give the link here. Will check them out.
29-12-2010, 12:17 PM
Problem signature:
Problem Event Name: BlueScreen
OS Version: 6.1.7600.2.0.0.256.1
Locale ID: 1033
Additional information about the problem:
BCCode: 4a
BCP1: 000000007793021A
BCP2: 0000000000000002
BCP3: 0000000000000000
BCP4: FFFFF88009077CA0
OS Version: 6_1_7600
Service Pack: 0_0
Product: 256_1
Files that help describe the problem:
C:\Windows\Minidump\122810-18018-01.dmp
C:\Users\Arnab@Boss\AppData\Local\Temp\WER-35100-0.sysdata.xml
this is the message i am getting after the restart eachtime..
29-12-2010, 12:21 PM
Super Moderator
No. I need the dump files. Post them to a online shared location. Last 4-5. Will run them through WinDebug utility.
Pick them from the path you mentioned "C:\Windows\Minidump\".
29-12-2010, 12:56 PM
4shared.com - free file sharing and storage - Login
here r the files uploaded...three files r there..??
29-12-2010, 01:16 PM
Super Moderator
Okay, thanks. Will look at them today evening, once I get back from office. Will update the thread here.
EDIT:
Just tried your link. It is taking me to the login. You would need to right click on the uploaded file, and give the respective link here.
30-12-2010, 04:26 PM
30-12-2010, 04:35 PM
Super Moderator
Ok. Thanks. Will check them out tonight.
Okay got this from one of the dumps..seemed the most comprehensive...
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck 4A, {7793021a, 2, 0, fffff88009077ca0}
Probably caused by : ntkrnlmp.exe ( nt!KiSystemServiceExit+245 )
Followup: MachineOwner
0: kd> !analyze -v
IRQL_GT_ZERO_AT_SYSTEM_SERVICE (4a)
Returning to usermode from a system call at an IRQL > PASSIVE_LEVEL.
Arguments:
Arg1: 000000007793021a, Address of system function (system call routine)
Arg2: 0000000000000002, Current IRQL
Arg3: 0000000000000000, 0
Arg4: fffff88009077ca0, 0
Debugging Details:
PROCESS_NAME: NokiaMServer.e
BUGCHECK_STR: RAISED_IRQL_FAULT
FAULTING_IP:
+0
00000000`7793021a ?? ???
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: VISTA_DRIVER_FAULT
CURRENT_IRQL: 2
LAST_CONTROL_TRANSFER: from fffff80002ec5469 to fffff80002ec5f00
STACK_TEXT:
fffff880`09077ad8 fffff800`02ec5469 : 00000000`0000004a 00000000`7793021a 00000000`00000002 00000000`00000000 : nt!KeBugCheckEx
fffff880`09077ae0 fffff800`02ec53a0 : 00000000`00000001 00000000`00260000 00000000`02b1e301 fffffa80`00000001 : nt!KiBugCheckDispatch+0x69
fffff880`09077c20 00000000`7793021a : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceExit+0x245
00000000`02b1e708 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x7793021a
STACK_COMMAND: kb
FOLLOWUP_IP:
fffff800`02ec53a0 4883ec50 sub rsp,50h
SYMBOL_STACK_INDEX: 2
SYMBOL_NAME: nt!KiSystemServiceExit+245
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: nt
IMAGE_NAME: ntkrnlmp.exe
DEBUG_FLR_IMAGE_TIMESTAMP: 4a5bc600
FAILURE_BUCKET_ID: X64_RAISED_IRQL_FAULT_NokiaMServer.e_nt!KiSystemSe rviceExit+245
And one showed this:
WRITE_ADDRESS: GetPointerFromAddress: unable to read from fffff800030ba0e0
fffffa7fbc55e529
FAULTING_IP:
nt!KiDeferredReadyThread+88c
fffff800`02e88f63 0083c9ff0fb6 add byte ptr [rbx-49F00037h],al
MM_INTERNAL_CODE: 7
BUGCHECK_STR: 0x50
PROCESS_NAME: essvr.exe
CURRENT_IRQL: 0
TRAP_FRAME: fffff880046d2890 -- (.trap 0xfffff880046d2890)
NOTE: The trap frame does not contain all registers.
Some register values may be zeroed or incorrect.
rax=fffffa8003ad1870 rbx=0000000000000000 rcx=fffffa80064b7800
rdx=fffffa8003ad1871 rsi=0000000000000000 rdi=0000000000000000
rip=fffff80002e88f63 rsp=fffff880046d2a28 rbp=fffffa8005fc2b30
r8=fffffa8003ad1870 r9=fffff80002ffce80 r10=fffffa8003a07cf0
r11=fffffa800645e560 r12=0000000000000000 r13=0000000000000000
r14=0000000000000000 r15=0000000000000000
iopl=0 nv up ei pl nz na pe nc
nt!KiDeferredReadyThread+0x88c:
fffff800`02e88f63 0083c9ff0fb6 add byte ptr [rbx-49F00037h],al ds:f100:ffffffff`b60fffc9=??
Resetting default scope
The first dump points to some Nokia service running on your system. You have Nokia PC Suite installed..?
The second one is pointing to Easy Energy Saver run by Gigabyte -- a motherboard utility. Try to turn it off.
Reason: Automerged Doublepost
04-01-2011, 12:45 PM
thanks dude..sorry i was busy so couldnt logged in !!
u r suggesting that i should turn off the energy saver and yes the n okia pc suite is installed wht to do abt it...???
dude do i need to format the hdd disk an then load the win7 again or by removing these apps will do...??
04-01-2011, 01:16 PM
Super Moderator
Turn off energy saver, and uninstall the Nokia software. All all the components one by one from the add/remove programs module.
Let us know.
04-01-2011, 02:42 PM
dude the nokia software is the nokia pc suite and with this i connect my nokia x6 and the net sometimes..??
should i uninstall and again reinstall it...?
04-01-2011, 03:29 PM
Super Moderator
I know what is Nokia Software. Just leave it off for a while, in the sense removed. We can find another alternative -- but need to get your system stable right...? Do not, uninstall and install the Nokia Suite back. Also turn off the Gigabyte energy saver module. Infact uninstall it.
04-01-2011, 10:20 PM
dude i hav uninstalled the easy energy saver but the problem still pursists..?? i am working on nokia pc suite so will uninstall later...!! but this time when i switch on the system it restarted three times and each time it asked that start windows normally or start repairs..???
then when i press the restart button it entered the windows but with same as above and then the blue screen pop up..!!
could b it bcas of hdd disk as i am using the seagate 7200.11 series of hdd which is known as faulty series...??
help me dude as it geetting me nuts..!!!
05-01-2011, 12:54 AM
Super Moderator
Remove the Nokia suite and let me know, you have to.
