Old 29-12-2010, 08:49 AM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
Unhappy Ide hard disk is not working
Hello guys my 320 gb ide hard disk is not detected by bios
it is not running
now im unable to acess my data
is there any chances to repair hdd as my pc is older configuration
and no sata port can any body tell me where i can repair my hdd
roshansoni is offline   Reply With Quote
Old 29-12-2010, 12:22 PM   #2 (permalink)
Never give up!!
jerrin_ss5's Avatar
Default Re: Ide hard disk is not working
well first of all check ur hard disk with some else's system or try replacing the connector cable even if its not workin then u can take ur hard disk to their resoective service center
AMD Phenom-II X4-810:| || Zotac 8200 A-E :sad:||OCZ PC2 6400 -2GB + 1GB (platinum + gold edition ):-) || Segate 250GB & WD green 500GB :||| ZOTAC GTX 460 1Gb DDR5 :grin:|| Cooler Master GX550W Bronze:||| AOC 2236VW:grin:.
jerrin_ss5 is offline   Reply With Quote
Old 08-01-2011, 03:38 PM   #3 (permalink)
no way to repair it.
taadhil is offline   Reply With Quote
LinkBack to this Thread: http://www.thinkdigit.com/forum/hardware-q/135476-ide-hard-disk-not-working.html
Ide hard disk is not working - Digit Technology Discussion Forum - Tech Discussion Forums in India This thread Refback 29-12-2010 09:54 AM
- by kool
- by ax3
