Old 28-12-2010, 09:37 PM   #1 (permalink)
g_goyal2000's Avatar
Default Laserjet P1007 - Light/faint printouts
I have an HP Laserjet P1007 printer.
I use Windows 7 Ultimate OS.
Driver version is v7.0.
Printer is out of warranty.
Economode is disabled in settings.
The printer was functioning fine about 2-3 months ago without any problem.
The problem is the printouts are very light/faint. They're not dark and crisp.
If I'm printing any text, they print okay but are not dark as they are supposed to be.
If I print any scanned image or any other pic, they're barely visible.
I have tried HP's Printing diagnostic utility.
It did not find any problem.
What could be the problem?
How can I solve it?
Dell Studio 1558, Intel i5 M430 @ 2.27 Ghz, 4 GB RAM, 1 GB ATI 5470 Mobility, 500 GB HDD, IDT HD Audio with Creative X-Fi MB software
g_goyal2000 is offline   Reply With Quote
Old 28-12-2010, 10:17 PM   #2 (permalink)
Default Re: Laserjet P1007 - Light/faint printouts
Image printing on this printer isn't a great experience actually.
Post some image/document which you printed. I'll print it on my printer and post a pic of the page.
What is the toner level?
Old 28-12-2010, 10:25 PM   #3 (permalink)
Pics attached.
Old 28-12-2010, 10:50 PM   #4 (permalink)
The second image was of low resolution for printing. (the forum's attachment system resized it perhaps)
(somewhat bad lighting)
Old 28-12-2010, 11:00 PM   #5 (permalink)
Hmm, your printouts are good, the way they should be.
I'll have to try another toner.
If that doesn't work, my printer's malfunctioning.
Any ideas?
Old 28-12-2010, 11:15 PM   #6 (permalink)
I used Ubuntu 10.10 though. Too lazy to set up the printer in Windows 7 on my laptop.
Check out the toner level. Go to the printer options/properties and you get the option over there. A page is printed which shows the toner level in percentage. Sorry for the vague instructions.
Old 28-12-2010, 11:41 PM   #7 (permalink)
All right.
I tried it on another computer with Windows XP.
Printed faint/light copies.
So the problem is neither with driver or OS.
Will get the toner checked on another printer.
Old 29-12-2010, 09:08 AM   #8 (permalink)
paroh's Avatar
One good tip for toner Never buy the old toner as the shelf life of the toner is 6 months
***********For computer related Problem PM me (If want's Doeacc A Level Project PM Me )************
paroh is offline   Reply With Quote
- by kool
- by ax3
