Old 28-12-2010, 12:30 PM   #1 (permalink)
Default network card not working
hi everybody, I am having a trouble with my network card. bios is showing lan card as enable, physical connection to the ethernet port is present but still there is a red cross on the network icon. troubleshooting shows no cable is connected(although physical connection to the ethernet port is present). I tried with a different cable still no result. It happened to my laptop one before(same problem) and after 3 days lan card works fine automatically. What is the problem with it and how can I solve it without waiting for more 3 days. Again the ethernet port leds are not glowing when cable is connected to it.
s.somrp is offline   Reply With Quote
Old 28-12-2010, 01:55 PM   #2 (permalink)
Super Moderator
asingh's Avatar
Default Re: network card not working
Remove the card and blow into the dock hard, place it back in.
asingh is offline   Reply With Quote
Old 28-12-2010, 05:54 PM   #3 (permalink)
My NIC is integrated with motherboard...
Old 28-12-2010, 08:01 PM   #4 (permalink)
Never give up!!
jerrin_ss5's Avatar
jst try to re install the network driver !!!
AMD Phenom-II X4-810:| || Zotac 8200 A-E :sad:||OCZ PC2 6400 -2GB + 1GB (platinum + gold edition ):-) || Segate 250GB & WD green 500GB :||| ZOTAC GTX 460 1Gb DDR5 :grin:|| Cooler Master GX550W Bronze:||| AOC 2236VW:grin:.
jerrin_ss5 is offline   Reply With Quote
Old 28-12-2010, 08:51 PM   #5 (permalink)
Super Moderator
asingh's Avatar
True. Overlay all the chipset drivers once. Should be fine.
Old 28-12-2010, 11:51 PM   #6 (permalink)
cute.bandar's Avatar
try a linux live cd to see if the network works in it. If you don't know any try - ubuntu lite
Computer parts search Engine(for india) : http://goo.gl/Sg8Yv
cute.bandar is offline   Reply With Quote
Old 29-12-2010, 12:55 AM   #7 (permalink)
mekalodu
iinfi's Avatar
where is the other end of the cable going? is it going to a cable internet wala's switch? or do u have a router in ur house?
can u check the other end of the cable is connected correctly?
iinfi is offline   Reply With Quote
Old 29-12-2010, 09:15 AM   #8 (permalink)
paroh's Avatar
Try to run the Network card at low speed Set the link speed to (10Mbps /Full Duplex)
To do this go to Control Panel Network Adapter expand it and double click on ur network card name go to link speed and set the speed to (10Mbps /Full Duplex).
***********For computer related Problem PM me (If want's Doeacc A Level Project PM Me )************
paroh is offline   Reply With Quote
- by kool
- by ax3
