Old 27-12-2010, 01:55 AM   #1 (permalink)
ithehappy's Avatar
Default Weird problem, any idea?
Well suddenly today my Monitor went in Power saving mode! (in XP) I waited about 2 minutes, then the System got restarted. I was just surfing at that time. This is a 2 weeks old PC (see my siggy), and it's a irritating and definitely weird problem. I had this same problem with my old rig, I thought it could be my C.M PSU but I was wrong. The only things I carried forward from my old rig is my Seagate HDD, XFX 9800GT and Creative sound card. Now I don't think a Sound card will create this. So the GPU and the HDD is left in the doubt list. Also, could that my Monitor? If it's the Monitor then why the Restart?
It's so frustrating, please give your opinions, what the problem might be.
Thanks in advance.
i7 950SABERTOOTH8GB RAMGTX560690II +TX650
SGS II
ithehappy is offline   Reply With Quote
Old 27-12-2010, 08:48 AM   #2 (permalink)
Super Moderator
asingh's Avatar
Default Re: Weird problem, any idea?
Guess it is the GPU. Since the relay signals fails to the monitor it turns off.
asingh is offline   Reply With Quote
Old 27-12-2010, 10:32 AM   #3 (permalink)
ithehappy's Avatar
Thanks. May I know why the restart? The relay signal fails and the Monitor goes off, it's okay, but the Restart is awkward.
So is it time to get rid of it? What would you advice?
SGS II
Old 27-12-2010, 12:38 PM   #4 (permalink)
Super Moderator
asingh's Avatar
The restart happens, cause the board will self reboot when it detects no VGA signal.
Test the GPU elsewhere.
Old 27-12-2010, 06:35 PM   #5 (permalink)
Never give up!!
jerrin_ss5's Avatar
so u mean to say that when there's no VGA signal that means no monitor connected the PC reboots or when there's no VGA signal from board then system reboots
AMD Phenom-II X4-810:| || Zotac 8200 A-E :sad:||OCZ PC2 6400 -2GB + 1GB (platinum + gold edition ):-) || Segate 250GB & WD green 500GB :||| ZOTAC GTX 460 1Gb DDR5 :grin:|| Cooler Master GX550W Bronze:||| AOC 2236VW:grin:.
jerrin_ss5 is offline   Reply With Quote
Old 28-12-2010, 12:22 AM   #6 (permalink)
Super Moderator
asingh's Avatar
I meant what I said. The board detects that there is no display signal -- or it has disappeared mid-way and re-boots to reset the accelerator.
Old 11-01-2011, 02:07 AM   #7 (permalink)
ithehappy's Avatar
Oh guys that problem wasn't there for a week and it came back again today. So frustrating...even my MoBo doesn't have any built in VGA so that I can test the GPU elsewhere and still work in my PC without the GPU.
Oh the problem is changed a bit, the Monitor does go to Power Saving mode but the system ain't restarting anymore.
I am totally shocked, absolutely idea less what to do. !!!!
SGS II
Old 11-01-2011, 09:38 AM   #8 (permalink)
Super Moderator
asingh's Avatar
Plug in another VGA and try.
Old 11-01-2011, 02:38 PM   #9 (permalink)
ithehappy's Avatar
VGA or GPU? Didn't understand.
SGS II
Old 11-01-2011, 02:42 PM   #10 (permalink)
Excessive happiness
furious_gamer's Avatar
Both same i guess. So try another GPU in your mobo or try your GPU in other system.
My First Android phone : Samsung Galaxy SL i9003 - Rooted & Gingerbread XXKPQ
Updated : superteekz_V2 ROM for XXKPQ.
PS Request
furious_gamer is online now   Reply With Quote
Old 11-01-2011, 02:46 PM   #11 (permalink)
Super Moderator
asingh's Avatar
Both are the same.
Old 11-01-2011, 02:53 PM   #12 (permalink)
Excessive happiness
Both are the same.
I know that but still a mild doubt...... It's been long time since i am active like this in forums.
PS Request
Old 11-01-2011, 03:44 PM   #13 (permalink)
Super Moderator
asingh's Avatar
Actually was not correcting you. I posted same time as you. the "^^" was for itheHappy, but your post came in between.
Old 11-01-2011, 06:07 PM   #14 (permalink)
abhidev's Avatar
Is that the way it really works...coz sometimes when my pc is running I disconnect my monitor so that i can watch movies on it by connecting the laptop...but my pc is kept running and it doesn't restart.
Core 2 duo E4500 2.2gHz , ASUS P5GCMX , 3GB Transcend , Corsair VX 550w, MSI R5770 HAWK Edition 1GB, CM HAF-922, LG W2243T 21.5" LCD, I-Ball Baton
abhidev is offline   Reply With Quote
Old 11-01-2011, 07:00 PM   #15 (permalink)
Excessive happiness
But here in his case the monitor is not disconnected and still no video signal, in that case it obviously restart. Correct me guys if i am wrong. Because i face these kinda issue when my 4670 troubled me a year ago.
PS Request
Old 11-01-2011, 08:14 PM   #16 (permalink)
Super Moderator
asingh's Avatar
No. What I meant is that if the board detects no video signal being generated (read VGA is not functioning) at times the system will reboot. It is the VGA right which is creating the video out signals, IF those are failing then the board can go into restart loops.
The OP has to try another VGA or try his VGA on another functional motherboard/system.
Old 12-01-2011, 04:13 PM   #17 (permalink)
abhidev's Avatar
But when the monitor is not connected...then there will be no vga signal generated anyways right?? Correct me if I am wrong?
Old 12-01-2011, 06:08 PM   #18 (permalink)
Super Moderator
asingh's Avatar
Signals would still be generated. The monitor is just a down-stream device.
Old 13-01-2011, 03:44 PM   #19 (permalink)
Fullbring
Zangetsu's Avatar
The Monitor is just a Plug&Play Device system will boot even if u don't connect any monitor..but the problem will be what u will see..nothin.... ......
& the inside cabby parts r dependent upon each other...if there is a problem is any part...the system will stop.....
Old 13-01-2011, 08:03 PM   #20 (permalink)
abhidev's Avatar
Thanx for the explanation...maybe thats the reason why coz of my GPU my monitor takes a little time to start as all the parts are running...only the monitor takes some time.
- by kool
- by ax3
