Old 26-12-2010, 07:56 AM   #1 (permalink)
digitalpainter
digibrush's Avatar
Default Heatsink broken!!!
Hi Friends,
Recenly I replace my old pc's mobo(intel d101ggc dead) with Asus P5KPL-AM/PS.
After instaling everything I noticed cpu( p4 2.66 G) temp was very high.
50-55 c in idle.
So I clean the heatsink again, also clean cpu's metal surface and apply TP,
try to insert HS and finaly manage to break one plastic clip of one leg.
It was stock HS comes with P4.
With one broken leg its seated almost properly, no jerkin when its run and even a very slight improvement in temp.
But i am sure 3 legs HS cannot reduce my temp, So i like to buy one.
Not very costly because i dont use this pc regularly.
And not a push system one(if I will break again).
So please suggest...
Intel DH55TC/Core i3 2.93Ghz/corsair Ram(4x2gb1333)/Sapphire HD5670 1Gb/Seagate 1Tb+500Gb/Seagate1TB External/CM Elite 430 & Real power Pro 460W/Creative Audigy+Inspire/iball pentablet/Razer Abyssus//Razer Goliathus/DellST2220L/Windows 7 Ultimate 64 bit.
It's good to touch the green, green grass of home.
digibrush is offline   Reply With Quote
Old 26-12-2010, 08:27 PM   #2 (permalink)
XLr8
arpanmukherjee1's Avatar
Default Re: Heatsink broken!!!
i bought a screw type retention like that of asus mb for 100/- at nehru place
then i bought CM n520
arpanmukherjee1 is offline   Reply With Quote
- by kool
- by ax3
