Old 24-12-2010, 05:13 PM   #1 (permalink)
Default Print spooler problem in win 2007
I have problems in using windows 2007 while installing the network printer given error print spooler service not started but service is on. After every time it shows same any solution
Last edited by Omkar.kulkarni; 24-12-2010 at 05:17 PM. Reason: Automerged Doublepost
Omkar.kulkarni is offline   Reply With Quote
Old 27-12-2010, 08:58 PM   #2 (permalink)
Stuck in Time...
Vyom's Avatar
Default Re: Print spooler problem in win 2007
First of all, there is no such thing as windows 2007! (I think u mean, win XP or Vista).
Secondly, how are you sure that print spooler is running? By the looks of the problem, I am skeptical of it.
To make sure that spooler is running,, goto Control Panel -> Administrative Tools -> Services, and look for a service called Print Spooler. Then check its status. It should be started. If it isn't then right click on it, and change Startup type to Automatic. Restart the system and check if this helps. All de best.
Marty: Hey, Doc, we better back up. We don't have enough road to get up to 88.
Doc Brown: Roads? Where we're going, we don't need, "roads!" :)
──── On the Internet you can be Anything you want. It's Strange that, so many people choose to be Stupid! ────
Vyom is online now   Reply With Quote
- by kool
- by ax3
