Old 23-12-2010, 08:56 AM   #1 (permalink)
Default I have so and so but nothing
Sir,
My systen configuration is as follows-
Mother board- Mercury pvm7
Proaessor- Intel Pentium 4 3.06 GHZ
Ram- DDR 1 2GB
OS- windows xp sp 3 and windows 7
DVD- Sony (SATA)
HDD- Seagate 500 GB (SATA)
SMPS- 450 W
Monitor- LG CRT 14 inch
1. I can not play IGI 2 smothly ( Game run slowly) in windows xp. what is problem ? Please help me.
2. I can not install VGA Driver in windows 7. In Mercury web site there is no VGA driver for Windows 7. Please help me.
3. who is best graphic card or agp card to install in my mother board ? Please provide name and model.
Please slove my problems and send ans. my mail id and print in DIGIT BOOK
Jagdanand kumar, Muzaffarpur, 9430064172
jagdanand kumar is offline   Reply With Quote
Old 23-12-2010, 09:25 AM   #2 (permalink)
Default Re: I have so and so but nothing
hello kumar,
as u can see the system requirements are here:
Minimum System Requirements
* - Processor: Pentium III or Athlon 700
* - RAM: 128MB RAM
* - Video Memory: 32MB VRAM
* - Operating System: 98/Me/XP
Recommended System Requirements
* - Processor: Pentium 4 or Athlon 1200
* - RAM: 512MB RAM
* - Video Memory: 64MB VRAM
and may i ask if u have any gfx card with your rig >?
and have you scanned your PC for virus or malware, which eats the RAM and maybe it will make the PC unstable during gaming.. I suggest download this tool from this website and scan your PC and but let me clear some doubts/
have your installed VGA drivers to this OS..
i will try my best to get you the driver!
wats your budget for it (card range is 2k to 5k{for DDR2})
here is the mercury specs, i dont think u can play on this one, and AGP cards are little costlier than cards and i would better suggest upgrade your PC to Athlon x3 or core 2 duo, with mobo..
download drivers here
http://bugup.co.cc
tejaslok is offline   Reply With Quote
Old 23-12-2010, 06:20 PM   #3 (permalink)
@jagdanand, remove win7 & install XP. this way game should run fine. else if you want to stick to Win7, you should get a new card but as mentioned by tejaslok your board have AGP slot. AGP cards are no longer avl in market & the few ones avl are very costly. do consider your decision.
- by kool
- by ax3
