Old 22-12-2010, 02:25 PM   #1 (permalink)
Exclamation usb pendrive not working
i have brought a PNY pendrive an year ago and it was working good until yesterday , i dunno what happened but it is not working fine, i tried to format ,but it said ''drive is write protected''. what should i do data is not imortant to me..
ndnvarma is offline   Reply With Quote
Old 22-12-2010, 04:33 PM   #2 (permalink)
The Sorcerer's Avatar
Default Re: usb pendrive not working
low level format. Someone will recommend you some softwares that does let you do this.
Hardware BBQ
The Sorcerer is online now   Reply With Quote
Old 22-12-2010, 05:26 PM   #3 (permalink)
Fullbring
Zangetsu's Avatar
@ndnvarma: get a low level format tool from HDDguru.com or search in PNY official website for some formatting utilities...
Old 23-12-2010, 06:14 PM   #4 (permalink)
127.0.0.1
mitraark's Avatar
Get a Tool called HP FOrmat tool , it does the job for me.
Intel i5 760 || Gigabyte H55 || Corsair 4GB 1333MHz Value || XFX HD5670 1GB
WD 2TB Green + Seagate 5900RPM 2 TB + Seagate Freeagent 1 TB x2
Corsair CX400 || Zebronics Bijli || Samsung P2350 23.5" || Altec Lansing VS2621
My Speedtest :D
mitraark is offline   Reply With Quote
Old 27-12-2010, 02:48 PM   #5 (permalink)
thanx i`ll give a try....
Old 27-12-2010, 03:03 PM   #6 (permalink)
Try a Low level frmat using HP format tool. It'll remove the protections and format the drive. Easy to use.
Good luck dude!
_VascoZ_ is offline   Reply With Quote
- by kool
- by ax3
