Old 21-12-2010, 10:21 AM   #1 (permalink)
Fullbring
Zangetsu's Avatar
Question Machine Crashed...
Hi Guys,
I was playing Crysis Warhead.Then suddenly my screen gone blank & the BSOD
dump screen is shown up with memory dump countdown timer....& machine restarted....
Then after re-boot...I again started crysis..then after the last level cutscene...
again the machine restarted itself....(but no Blue screen this time)....it all happened on sunday....I thought some file is corrupt in game so turned-off the machine...
Then On Monday when is started the machine.....it denied to start..all fans were working properly...monitor was off & HDD & DVD writer LEDs were blinking with 1sec gap.....I dont know what happend....then I kept the machine as it is...then suddenly after 2~3mins the machine started automatically....& I completed the remaining levels of Crysis Warhead finally
without any crash.
So,cud anybody tell me what all had happened???...I dnt wanna face this issue anymore....
Old 21-12-2010, 10:27 AM   #2 (permalink)
Super Moderator
asingh's Avatar
Default Re: Machine Crashed...
Start with running memtest on the RAM.
asingh is offline   Reply With Quote
Old 21-12-2010, 10:32 AM   #3 (permalink)
Fullbring
Zangetsu's Avatar
@asingh: so u doubt dat its RAM problem....Btw how much time does Memtest takes...I have not done this before....
Old 21-12-2010, 11:05 AM   #4 (permalink)
Super Moderator
asingh's Avatar
Usually over night run.
Old 21-12-2010, 12:20 PM   #5 (permalink)
Never give up!!
jerrin_ss5's Avatar
it usually takes abt 1hr or so for me !!!
AMD Phenom-II X4-810:| || Zotac 8200 A-E :sad:||OCZ PC2 6400 -2GB + 1GB (platinum + gold edition ):-) || Segate 250GB & WD green 500GB :||| ZOTAC GTX 460 1Gb DDR5 :grin:|| Cooler Master GX550W Bronze:||| AOC 2236VW:grin:.
jerrin_ss5 is offline   Reply With Quote
Old 21-12-2010, 12:49 PM   #6 (permalink)
Super Moderator
asingh's Avatar
Through the DOS version..?
Old 21-12-2010, 01:37 PM   #7 (permalink)
Fullbring
Zangetsu's Avatar
Oh..No....then i've to switch-off the monitor while doing this....
Old 21-12-2010, 01:54 PM   #8 (permalink)
abhidev's Avatar
Can the game not being a legit copy be reason???
Core 2 duo E4500 2.2gHz , ASUS P5GCMX , 3GB Transcend , Corsair VX 550w, MSI R5770 HAWK Edition 1GB, CM HAF-922, LG W2243T 21.5" LCD, I-Ball Baton
abhidev is offline   Reply With Quote
Old 21-12-2010, 02:09 PM   #9 (permalink)
Fullbring
Zangetsu's Avatar
haven't u read my last lines...even i thought the files may be corrupt but game was perfectly ok....coz it ran smoothly @ last....
its a technical problem related to either Graphics Card/RAM/PSU????
I'll have 2 figure it out whats the reason for this error...
Old 21-12-2010, 02:36 PM   #10 (permalink)
Super Moderator
asingh's Avatar
Why OH NO. Just switch of the monitor from the monitor on/off button.
Old 21-12-2010, 03:19 PM   #11 (permalink)
abhidev's Avatar
It also happens when some game files are corrupt...everytime your game crashes or windows get restarts due to those crashes...they may corrupt some of the files too.
Old 21-12-2010, 05:00 PM   #12 (permalink)
Fullbring
Zangetsu's Avatar
I know this fact...but the problem is something else coz the game ran smoothly where i got the BSOD.....
@asingh: how long it took for u to complete the memtest?
Old 21-12-2010, 05:29 PM   #13 (permalink)
Never give up!!
jerrin_ss5's Avatar
i used the memtest by live booting from ubuntu where an option for memtest is there & it took me abt 1hr or so and then it starts repeating the same process
Old 21-12-2010, 07:52 PM   #14 (permalink)
XLr8
arpanmukherjee1's Avatar
memtest takes about 4 - 4.5 hrs on my system
also run system stablity test for approx 2hr after restart
arpanmukherjee1 is offline   Reply With Quote
Old 21-12-2010, 10:16 PM   #15 (permalink)
Super Moderator
asingh's Avatar
Never knew it was so fast with Ubuntu. Thanks...!
Old 22-12-2010, 09:57 AM   #16 (permalink)
Fullbring
Zangetsu's Avatar
Hmm..ryt now machine working properly though its under observation,
didnt know y it happened....
will run memtest whenever i get time....
Old 22-12-2010, 02:10 PM   #17 (permalink)
abhidev's Avatar
You don't hv to be there while the test is running...you can keep it overnight and check the status the next morning.
Old 10-01-2011, 03:05 PM   #18 (permalink)
Fullbring
Zangetsu's Avatar
I got the reason for the problem it was my 2GB RAM.....
one of it is corrupted now & I've sent the RAM for RMA to corsair...but it will take 15days to get the replacement done....& their service center is in bangalore....
but the good thing is I've 10yrs of warranty on my RAM
Old 10-01-2011, 03:32 PM   #19 (permalink)
abhidev's Avatar
10 yrs....thats awesome man!!! which other companies provide this kind of Warranty??
Old 10-01-2011, 03:38 PM   #20 (permalink)
Fullbring
Zangetsu's Avatar
^^yup 10yrs.....but i think its reduced to 5yrs now by corsair itself.....
& no other company provide this much of warranty....
Old 10-01-2011, 03:47 PM   #21 (permalink)
Yeah you are correct!!Its now 5 years.
AMD Athlon II X4 635 || Biostar MCP6P3 || 2GB Zion & 2GB Corsair DDR3 1333MHz || Seagate 1TB + Seagate 500GB || XFX HD4650 || FSP Saga II 500W || Zebronics Fantasy || LG W2043T
ssb1551 is online now   Reply With Quote
- by kool
- by ax3
