Old 21-12-2010, 09:44 AM   #1 (permalink)
Default my computer is not booting ..
hello friends,
When I start my computer, it don't boot. Monitor don't get display
and one long beep comes from my cpu again and again. I checked my Ram.
I put it again after cleaning but still same probs is there.
what to do ?
sonali321 is offline   Reply With Quote
Old 21-12-2010, 12:24 PM   #2 (permalink)
Never give up!!
jerrin_ss5's Avatar
Default Re: my computer is not booting ..
it might that u RAM has stopped working
to make sure that its ur RAM problem try some else's RAM on ur mo-bo and check whther ur PC boots up !!!
AMD Phenom-II X4-810:| || Zotac 8200 A-E :sad:||OCZ PC2 6400 -2GB + 1GB (platinum + gold edition ):-) || Segate 250GB & WD green 500GB :||| ZOTAC GTX 460 1Gb DDR5 :grin:|| Cooler Master GX550W Bronze:||| AOC 2236VW:grin:.
jerrin_ss5 is offline   Reply With Quote
- by kool
- by ax3
