I have a 5+ year Old PC at home. Recently , it stopped working in the following manner.
I was just browsing on Firefox , there were only 3 tabs open , i had nothing running on background , no updates or cleanups , nothing , i am sure PC CPU usage was low .
I had not installed any new Hardware or Software or Drivers. I did absolutely nothing out of the ordinary normal work , just plain browsing , and i was on this SIte only , no FLASH / SL site or anything.
Suddenly , BSOD [ Blue Screen Of Death ] showed up for a second , and my PC 'apparantly' restarted, i.e. , my CPU Fan was still whirling around , PC Green light was oN , the yellow blinked a few times.
But now nothing showed up on screen. Not even the Intel Logo that comes at startup. Although the CPU FAN is working , the light of the DVD is blinking , the hard disk is also whirling , and a small green led light is also on the motherboard , nothing is showing up on screen . I cannot access anything , including BIOS [ as i said , not even the Intel logo is showing at startup..
I tried reconnecting the SATA Cables , adjusting the 20 pin , reinstated the RAM Modules , cleaned the CPU Fan , but still the same.
What might be the problem ?// I am thinking my Motherboard might be fried, but does the CPU fan run after that , i am not sure , so had to ask
Also , can i get a motherboard now for my current CPU ??with DDR2 RAM support ??
My PC Config:
Intel Pentium 4 531 3 GHz
Intel 915GAVL Motheboard
512 + 256 DDR400 RAM
1 TB Seagate
Lite-On DVD
XFX 8600GT 256MB DDR3
iBall Cabinet
400W SMPS [ Came with Cabinet ]
Samsung 17" CRT
All except 8600GT and 1 TB , bought on September 2005.
