Re: SATA DVD Writer on a PATA motherboard
JohnephSi, if you use SATA to PATA converter then you will loose the speed advantage of SATA. Better choice is add an SATA-Addon Card to your PCI slot. It will help you to add more sata components like SATA HDDs. Price will be within 1K.
Phenom II X6 1090T@3.6GHz|8 GB RipjawX 1600 MHz|1+2TB Seagate + 1 TB WD Green 64MB Cache|Sabertooth 990FX|HD 6870CF|GT 240 1 GB GDDR5 PhysX|CM690II Advanced|G2220HD|TX850 V2|2 CM 1600RPM FAN|MX518|Razer Goliathus|Razer Arctosa|Corsair HS1A|APC1.1KVA
