Why do you think that happens? Which is more reliable?
I think my processor is running too hot while idle. I'm using a Cooler Master V8 cooler. No OC'ing so far. I have attached it properly and have tied up cables etc. Would a picture of my cabinet help?
Re: Difference in Temperature between Speedfan and Realtemp.
I guess speed fan is measuring the tCase temp while realtemp is measuring tJunction temps thats CPUS have 2 diodes at diff locations on the CPU die to measure the temps... Hence the diff. As asingh suggested stick to Real temp.
^^ In OPs case Speedfan is wrong about showing temp but it's not wrong about showing 12 cores. Look carefully - those 12 boxes are for cpu usage display and as core i7 980X is a six core hyper threaded cpu windows will recognize it as a 12 core cpu, Task manager will show 12 boxes for cpu usages and so does speedfan.
@ OP - the temp you are getting with V6 is just fine and if you are interested start OCing.
Originally Posted by topgear
^^ In OPs case Speedfan is wrong about showing temp but it's not wrong about showing 12 cores. Lookmcarefully - those 12 boxes are for cpu usage display and as core i7 9801X is six core hyper threaded cpu you windows will recognize it as a 12 core cpu, Task manager will show 12 boxes for cpu usages and so does speedfan.
Didn't know that
__________________ | A Bit IP35-Pro | E8400 | GTS250 | Gskill 2x2GB | 1.9 TB | CM EP+ 460W | 2x DVD-RW|
| Nokia 2700c |
