i am using logitech cordless mini mouse from last 1 yr.. 2 days back it was showing red indication dat was of battery low.. so i replaced the cell with a new one..
bt i dont knw wht happened den?? bt it has stopped working now??
in control panel~>devices its showing USB Receiver too..
help me guys wid dis problem..
The most probable cases with wireless mouse stops working is:
1) A non functional receiver ( Are you getting the green light on the receiver?)
2) Discharged batteries.
In case of the former , if you are within the 3 year warranty period you are covered.
well there is a green light on mouse.. And USB receiver dont have any led inside.. bt in Control Panel its showin USB receiver has been recognised.
bt still the same prob.
i have replaced the batteries too..
