11-12-2010, 08:39 AM
PC Boot automaticaly, after Put on Standby AND After Switching On UPS, PC Boot Itself
Hello,
(1) When I Switch ON UPS, then PC Restart (Boot) automatically.
(2) When I put PC to Standby Mode, even then then it Restart (Boot) automatically.
What is the problem
11-12-2010, 11:30 AM
Super Moderator
Re: PC Boot automaticaly, after Put on Standby AND After Switching On UPS, PC Boot It
System configuration.
11-12-2010, 08:12 PM
dear, following is system config: -
Windows- XP Professional SP3
Processor- Intel Pentium D, 3.40Ghz
RAM- 2.5 GB
Mother Board- Intel 946GZ Express Chipset Family
Today another problem arise i.e. After shutting down, PC start automatically.
Where is fault?, why these problems appearing one by one. Please tell solution.
RAM- 2.5 GB
11-12-2010, 08:43 PM
Super Moderator
Powersupply..?
11-12-2010, 09:07 PM
sorry, are your asking or telling?
RAM- 2.5 GB
11-12-2010, 09:14 PM
Super Moderator
Asking.
11-12-2010, 09:40 PM
@jbohar, what is the SMPS you having?
@asingh, can't it be cause of some setting in BIOS? some motherboard have option in BIOS that turn PC on as soon as they get power. can't it be same case with OP?
18-12-2010, 09:25 AM
Never give up!!
check whther ur power supply is delivering proper power !!
if ur mo-bo has on-board LED's use that to gauge it !!!
AMD Phenom-II X4-810:| || Zotac 8200 A-E :sad:||OCZ PC2 6400 -2GB + 1GB (platinum + gold edition ):-) || Segate 250GB & WD green 500GB :||| ZOTAC GTX 460 1Gb DDR5 :grin:|| Cooler Master GX550W Bronze:||| AOC 2236VW:grin:.
19-12-2010, 10:40 AM
Thanks but problem is still arising. while running, sometime PC start automatically. Also PC Starts on Shut Down & if putting on Standby.
@ Sam: Power Supply is Tech-Com, Model - PSP 4500 (450 Watt).
Where in BIOS this setting is situated?
@ Jerrin: Please tell how proper distribution of Power Supply can be checked?
Also, IF mo-bo has on-board LED', then where it situated & on mo-bo & how to gauge it?
Please tell how to create a Image with Norton Ghost at this Post: -
With NortonGhost, HowToCreate ImageOf 'Installed Software Only'To Solve Wndws Problms
RAM- 2.5 GB
Reason: Automerged Doublepost
19-12-2010, 03:09 PM
Never give up!!
the led placement for mo-bo differ for each brand !!
but in ur case i think ther's no LED on ur mo-bo!!
so now the only option is to check ur mo-bo with someone else's power supply !!!
19-12-2010, 05:36 PM
Thanks jerrin.. I'll test mo-bo with other Power Supply. But from last 2-3 years, PC is running on 450 Watt power Supply. My friend has Power Supply of 650 watts, if I test mo-bo with that (650 Watt Power Supply). Can it cause harm to mobo or to HDD??
Also please see above Post URL Link regarding Norton Ghost.
Thanks.
RAM- 2.5 GB
19-12-2010, 08:15 PM
Super Moderator
At OP. For starters try to reset CMOS. Remove the PSU cable, and press the chassis on/off button for 2-3 seconds. Then remove the CMOS battery for 2 minutes. Plug it back ion and see if you can boot it normally.
20-12-2010, 02:11 PM
Thanks Asingh.
1st Step: Are you talking about removing PSU cable from mo-bo??. if yes, this step is ok.
2nd Step: But my PSU have not On/Off button. Should I On/off UPS button at this point.
3rd Step: Pluck CMOS for 2 minutes.
4th Step: Fix CMOS in mo-bo.
5th Step: Fix PSU Cable.
Actually I am new to hardware so asking this. are you talking about these steps??.
RAM- 2.5 GB
20-12-2010, 02:47 PM
Super Moderator
Just do 3,4,5. Keep the power outlet connection remove.
20-12-2010, 04:45 PM
Never give up!!
Thanks.
generally higher watts PSU won't damage ur mo-bo but make sure the PSU ur gonna use is a branded one !!!
27-12-2010, 07:52 PM
Thanks guys, your suggestions works.
Booting problems were due to faulty power supply, replaced it & all gone.
@ Jerrin: Now Champion named Power supply is running. Is it fine??.
RAM- 2.5 GB
27-12-2010, 09:03 PM
^^ please stay away from PSU that reads: extreme, champion or super, etc. these names are used to fool the user to buy. drop that PSU & get a good one like Corsair (if your pocket deep) or FSP (for 2k & below). if you'll upgrade your PC to a better one, get Corsair or at least buy FSP Saga II 350W. its low cost & will keep your PC safe.
28-12-2010, 10:13 AM
Never give up!!
well never heard of such a PSU go for a branded one such as cooler master or corsair !!
