Old 08-12-2010, 11:42 AM   #1 (permalink)
blademast3r's Avatar
Lightbulb Does HDMI cable give better quality than DVI?
Googled for this but havent found anything definitive.
I have an ati HD 5750 card and benq G2220 full HD monitor.. I run pretty much everything at 1920X1080 res. Currently using a DVI cable. Will shifting to HDMI cable provice any VISUALLY noticable differences in quality??
blademast3r is online now   Reply With Quote
Old 08-12-2010, 11:53 AM   #2 (permalink)
Super Moderator
asingh's Avatar
Default Re: Does HDMI cable give better quality than DVI?
Nopes, there will be no change in the visual aspect.
asingh is offline   Reply With Quote
Old 08-12-2010, 12:33 PM   #3 (permalink)
A small addendum:
The only advantage HDMI has over DVI is that it can carry Digital AUDIO signals as well, useful only if you're connecting a STB to your TV.
DVI and HDMI both transmit digital video signals , so expect no change in clarity.
Intel C2Q Q6600 | GA G41M-Combo | Coolermaster Gemini II-S | 8GB DDR3 1333 | MSI GTX 560Ti | Corsair TX750W
SteamID: Tachyon1986 | BF3: ttachyon1986 | League of Legends: IKillLadyHawks
Tachyon1986 is offline   Reply With Quote
Old 08-12-2010, 01:12 PM   #4 (permalink)
Fullbring
Zangetsu's Avatar
aha...atleast good change.. from VGA to DVI....
Old 08-12-2010, 01:40 PM   #5 (permalink)
Ahhh cool.. no point upgrading then! Thanks guys
- by kool
- by ax3
