Old 07-12-2010, 03:03 PM   #1 (permalink)
Default Need help regarding laptop ram
Hey hello every1,
I am new to this forum and if by ny mistake pls forgive me n correct me.
I have a compaq presario laptop A900 series dual core, with 2 gb ddr2 ram. I want replace my 1gb ram with 2gb so that in all i can I have 3gb ram. Both ram have 333Mhz. I want to know whether I can upgrade it with 1033Mhz 2gb ddr2 ram. I read a post using two different company RAMs but I couldnt figure it out. Can u please help me.
These are the cpuz images of my processor and spd. Pls help thanking you in advance....
shashank is offline   Reply With Quote
Old 07-12-2010, 07:45 PM   #2 (permalink)
Default Re: Need help regarding laptop ram
Is there nybody who can help?
Old 07-12-2010, 08:13 PM   #3 (permalink)
Super Moderator
asingh's Avatar
You should be able to upgrade if the specification is the same (example PC2-5300) even if different company DIMMs. Not sure if your board will support 1033MHz though the rated FSB is 532 Mhz.
asingh is offline   Reply With Quote
Old 07-12-2010, 08:42 PM   #4 (permalink)
laborare est orare
Cilus's Avatar
i don't think Laptop DDR2 modules support more than 800 MHz in case of normal laptops. Try to find Ram with maximum speed of 800 MHz, but 533 MHz is advisable for its maximum compatibility.
Phenom II X6 1090T@3.6GHz|8 GB RipjawX 1600 MHz|1+2TB Seagate + 1 TB WD Green 64MB Cache|Sabertooth 990FX|HD 6870CF|GT 240 1 GB GDDR5 PhysX|CM690II Advanced|G2220HD|TX850 V2|2 CM 1600RPM FAN|MX518|Razer Goliathus|Razer Arctosa|Corsair HS1A|APC1.1KVA
Cilus is online now   Reply With Quote
Old 07-12-2010, 09:58 PM   #5 (permalink)
thanks sir for the quick reply really appreciable.....1 more doubt I have suppose if I find a 2gb ddr2 ram of 800 MHz or I take a 2gb 533 MHz ddr2 ram will it be compatible with my 1gb ddr2 333MHz ram. I am thinking to have total of 3Gb ram i.e 1gb which I already have + 2gb which m gonna purchase.
Thanking you once agian....
Old 07-12-2010, 10:44 PM   #6 (permalink)
Super Moderator
asingh's Avatar
Could you post a picture of the 'mainboard' tab from CPU-Z.
Thanks.
P.S.:
No one is a 'sir' here'
Old 08-12-2010, 07:09 AM   #7 (permalink)
ok.....
Old 09-12-2010, 05:19 AM   #8 (permalink)
I still didnt get an answer can somebody pls reply........................
Old 09-12-2010, 10:04 AM   #9 (permalink)
Super Moderator
asingh's Avatar
Actually do not add that extra ram. Your board has a GL960 chipset. Below is the link. It supports a maximum of 2GB RAM. Buy a RAM module similar to what you have and stay with 2 GB total. Sorry about this. Should have asked your motherboard details in the first post.
GL960 Intel Specification Sheet.
Old 10-12-2010, 11:15 AM   #10 (permalink)
Dho.......dats really bad but again two questions wander my mind; actually I was upgrading to have windows 7 ultimate on my laptop.
My questions are if I put windows 7 x64 bit ultimate will it work fine with 2gb ram.
n second you told "Buy a RAM module similar to what you have" I didnt really get what you meant by this? Did u mean to say I can buy 2gb 1033Mhz ram PC2-5300?
Awaiting an early reply........
Old 10-12-2010, 11:36 AM   #11 (permalink)
Super Moderator
asingh's Avatar
Win7 should work fine with 2GB RAM. Heck, I am using it on my 1 GB + Atom Processor Netbook.
Get PC2-5300.
Old 10-12-2010, 05:05 PM   #12 (permalink)
but i already have 2gb ram so wat do actually want to say by get pc2-5300?n will windows x64bit work fine with it?
Old 10-12-2010, 05:30 PM   #13 (permalink)
Super Moderator
asingh's Avatar
Oh. Then you cannot go beyond 2 GB. The chipset does not support it.
- by kool
- by ax3
