Old 06-12-2010, 12:05 PM   #1 (permalink)
Exclamation Computer short beeps and hangs for 2 sec
I seem to have an unusual problem here. Sometimes when I access my drive (immediately on double clicking) there come a short beep from the cabinet (it is not from the small speaker which beeps in case of RAM malfunction) I think its from the drive itself, and then the drives stops responding for 2 seconds (but the whole PC works fine in the background, its as if the whole drive is being read back which causes the 2 sec delay). But every time it happens it is the same a small beep is followed by the 2-3 sec delay. Then everything resumes normal.
It started happening when I installed my new Western Digital (Green) 1TB hard Disk 4 months ago. My other drive is Seagate 7200.11 Barracuda 500GB.
The WD hard disk is the D Drive, with no partitions (complete 940GB)
The Seagate is partitioned in two C (200GB, Windows 7 Ultimate 64bit installed) and E(265GB).
This problem usually happens with the Western Digital Drive. And this problem happens at most 2-3 times a day, or sometimes it doesn't even happen. (My PC is on for approx. 14 hours a day).
I even defragment my drives once a month.
Is something wrong with the Drive?
My PC config is:
Intel E7300 2.66GHz, Gigabyte GA-G31M-S2L, MSI GeForce 9500GT 1GB GDDR3 OC Edition, Corsair CX400W, Dynet RAM 4GB.
KunalAggarwal is offline   Reply With Quote
Old 07-12-2010, 04:30 PM   #2 (permalink)
Never give up!!
jerrin_ss5's Avatar
Default Re: Computer short beeps and hangs for 2 sec
beeps usually come form mother board but in your case its diff i suppose
anyways if HDD is ur doubt check your HDD with speedfan s/w it has SMART readings check if ur HDD health is OK although u can't completely rely on this readings but still u can atleast confirm something !!!!
jerrin_ss5 is offline   Reply With Quote
Old 07-12-2010, 09:55 PM   #3 (permalink)
avichandana20000's Avatar
My PC config is:
Download HDD SENTINEL. Great software. Run the performance test.
NZXT PHANTOM WHITE|GA990XA UD3|955BE 3.6(O.C.ed)|MX-2|HYPER EVO|SAPPHIRE 6670 DDR5|DELL SP2309W|CORSAIR XMS 2X2GB 1333|450VX|SEAGATE 1TB|LOGITECH G110|APC 650 VA|
avichandana20000 is online now   Reply With Quote
Old 08-12-2010, 10:21 PM   #4 (permalink)
I used HDD Sentinel and it showed this for my Seagete 500GB HDD :-
Health : 37% (Acceptable)
Temp : 26C
"There are 8 bad sectors on the disk surface. The contents of these sectors were moved to the spare area.
Problems occurred during the spin up of the disk 21 times. This can be caused by the disk itself or huge power load (weak power supply).
At this point, warranty replacement of the disk is not yet possible, only if the health drops further.
It is recommended to examine the log of the disk regularly. All new problems found will be logged there."
Unexpected, though, the WD HDD : Health : 100%
HD Tune Pro showed these errors (attached PNG image)
Is there any way to fix these errors.
Old 08-12-2010, 10:45 PM   #5 (permalink)
it seems that that the bad sector has developed at the beginning of the disk.
go to my computer. right click on the c drive.=> properties=>TOOLS tab=>Error Checking. Click on CHECK NOW. Tick both the boxes and click START. this will take several minutes. then shut down and open again. see if problem persists.
if that does not work see formatting and reloading the OS solves the problem or not. OR wait for more suggestions.
- by kool
- by ax3
