Old 05-12-2010, 08:26 PM   #1 (permalink)
Default Will ther be any lag in gaming performance on a WD caviar green drive ?
I've an idea to get a 500GB WD drive.
Can some one tell me what is the exact rotational speed of the platters ?
Will Lower speeds affect gaming or any other performance ?
Phenom II X6 1055T|Gigabyte 880GM-USB3|Transcend 4GB DDR3 1333MHz| Benq G2220HD|PowerColor Radeon HD5770|Seagate 500GB|Logitech MK250|CM Elite 310|Zebronics Pro 600w|Creative A100 2.1 speakers|LG DVD|
giprabu is offline   Reply With Quote
Old 05-12-2010, 08:33 PM   #2 (permalink)
The Sorcerer's Avatar
Default Re: Will ther be any lag in gaming performance on a WD caviar green drive ?
Avoid green edition for the time being as they have failure rates- as do mine. I insisted on atleast blue edition so they replaced mine with blue.
Besides, IIRC the price difference between green and black is somewhat negligible. Confirm the price for blue (I don't think its on stock but I don't about now) and black, make the decisions accordingly. Rather than green, I would recommend 7200.12 rpm drives.
But generally, I doubted. I am using an older version of the green drives as a primary OS and it doesn't show any lag.
Hardware BBQ
The Sorcerer is online now   Reply With Quote
Old 05-12-2010, 08:39 PM   #3 (permalink)
Jaskanwar Singh's Avatar
If its a 7200rpm 32mb(cache) green, its fine. Try get 7200.12 seagate.
Old 05-12-2010, 08:55 PM   #4 (permalink)
Believe Me or Not!!!
it will do just fine...
But if you havnt bought it yet go for Seagate 7200.12
NainO is offline   Reply With Quote
Old 05-12-2010, 09:24 PM   #5 (permalink)
gaming performance is okay but the drive is slow and indecent
Saurav2007 is offline   Reply With Quote
Old 05-12-2010, 09:43 PM   #6 (permalink)
@everyone :
but based on the usage, the 'intelli power' technology delivers any rotational speed between 5400rpm and 7200 rpm rite ?
Say if at some situation , the speed is 6000rpm, the performance diff btwn a 7200 rpm drive and this green drive should be negligence.
Isn't it just like 'Turbo boost' ..?
- by kool
- by ax3
