Old 05-12-2010, 03:59 PM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
AMD Fanboy
vishalg's Avatar
Exclamation noisy phenom 955 stock fan
i have recently bought an phenom 955BE and using it with the stock cooler on asus m4A87TD Evo mainboard
now my problem is that even at normal operating conditions its very noisy
even at 1100-1200rpm and 36-40C it is more than audible and is really irritating in night
i have cool n quiet enabled in bios and have power saver setting selected in windows
are all phenom series coolers noisy or do i have a faulty one
will cooler master hyper tx3 be any good?? (i can only afford that)
AMD Phenom II X4 955 BE @ 3.4Ghz | Asus M4A87TD-EVO | Asus EAH 6850|2X2GB Corsair DDR3 1333Mhz | 2X250GB Seagate Barracuda | Corsair VX550W | Cooler Master Hyper 212+ | Cooler Master Elite 430 | Viewsonic VX1932WM |
vishalg is offline   Reply With Quote
Old 05-12-2010, 06:28 PM   #2 (permalink)
Default Re: noisy phenom 955 stock fan
^^ the fan isn't good one. so its noisy. as you can afford only TX3, so get it. TX3 will cool it + allow you try some overclock also safely
Old 05-12-2010, 07:18 PM   #3 (permalink)
AMD Fanboy
vishalg's Avatar
will the tx3 be silent??
Old 05-12-2010, 07:24 PM   #4 (permalink)
bajaj151's Avatar
Ya..fan is noisy.I too having the issues with 1055t stock fan..
@Sam.Shab
--> Please suggest me cooler within 3k.
--> Sapphire 5670 512mb is not available...Should I buy 1GB ver or wait price drop for 5770 ??
Phenom x6 1055T 3.75 GHz | MSI 890GXM G65 | Corsair XMS3 2*4GB 1600mhz | BenQ E2200HD | Xbox 360 Controller | Seagate 2TB | CM HAF 922 | Corsair VX 550 | Logitech MX 518 | Logitech Wireless Keyboard | Sapphire 7850 OC
bajaj151 is online now   Reply With Quote
Old 05-12-2010, 08:22 PM   #5 (permalink)
yah. under normal operation its should be quite or inaudible. but when under load (read gaming) the fan will spin fast, but still the noise will be lower than AMD stock coolers
Originally Posted by bajaj151 View Post
Y@Sam.Shab
about the HSF, not much idea. Hyper212 (not the +) is a good buy. priced below 3k. but please confirm it once.
and for HD5670, if its priced below 5.5k, get the 1Gb version. cause its been long since HD5670 came out. so waiting more mayn't yield the expected result. you may get slight discount (100-150 bucks) in HD5770 or other HD5series cards but that mainly will be to clear stock & pave way for HD6670 or some cards like this from the green camp.
Old 05-12-2010, 09:02 PM   #6 (permalink)
AMD Fanboy
vishalg's Avatar
cm 212 plus is available at smc for 1850
is it worth spending 500 bucks for 212 plus as against tx3??
coz there isnt much to choose from the specs between the two
will the 212 be quieter than tx3 as it has a bigger fan and lower rpm than tx3?
also i noticed that smc is offering 212 model RR-B10-212P-G1(on cm -usa site) while delta peri are offering RR-B10-212P-GP (on cm -india site)!!!!
whats the diff between the two???
is 1850 a good price for 212??
LinkBack to this Thread: http://www.thinkdigit.com/forum/hardware-q/134717-noisy-phenom-955-stock-fan.html
Thread noisy phenom 955 stock fan | Digit Forum | BoardReader This thread Refback 20-09-2011 12:22 AM
- by kool
- by ax3
