Old 03-12-2010, 07:40 PM   #1 (permalink)
Default System does not boot
I have a serious problem and I doesn't seem to figure it out.
Problem is, whenever the power is turned on from the main switch the system starts on its own and then shuts down within 3-4 seconds.Pressing the power button on the cabinet does not start the PC. Main switch needs to be put off and again put on but problem remains same.
I tried using a new power supply, removing the RAM and cleaning the dust from the system.
Configuration is,
Motherboard: ASUS M2N68-AM Plus
CPU: AMD Phenom II X2 550 Black Edition
RAM: Transcend DDR2 800 (2+2GB)
Hard Drive: WD 500GB
Cabinet: iBall
sama2802 is offline   Reply With Quote
Old 03-12-2010, 08:24 PM   #2 (permalink)
Default Re: System does not boot
remove the CMOS battery for sometime & reinsert it. this will reset BIOS & your problem may get solved. do it & than report back if the problem solved.
Old 04-12-2010, 01:37 PM   #3 (permalink)
I tried removing & reinserting the CMOS battery, but of no use.Power is not supplied to the motherboard when the power pin on the board is touched by a screw driver.
Old 07-12-2010, 12:02 AM   #4 (permalink)
avichandana20000's Avatar
your PSU fan is running?
BTW what PSU u r using?
NZXT PHANTOM WHITE|GA990XA UD3|955BE 3.6(O.C.ed)|MX-2|HYPER EVO|SAPPHIRE 6670 DDR5|DELL SP2309W|CORSAIR XMS 2X2GB 1333|450VX|SEAGATE 1TB|LOGITECH G110|APC 650 VA|
avichandana20000 is online now   Reply With Quote
Old 07-12-2010, 04:24 PM   #5 (permalink)
Never give up!!
jerrin_ss5's Avatar
does any beep sound come while booting if so check whther CPU is not over heating! try placing the heat sink properly! if that's not the problem check whther the board getting proper power supply if the board has onboard LED's for displayin good or bad power verify from that !!!
jerrin_ss5 is offline   Reply With Quote
Old 15-12-2010, 04:41 PM   #6 (permalink)
There was a problem with the motherboard.I gave it to the company.They declared it as irreparable.I got a replacement for it.
Thanks all.
- by kool
- by ax3
