Old 30-11-2010, 04:22 PM   #1 (permalink)
Default Machine Heating Up !!!!
Hey Guys !!!
My Config :
i5 760
Asus P7P55D-E
Corsair 2x2Gb (1600 Mhz)
WD Green 500 Gb
Hitachi 80 Gb (Old one)
Corsair GS 600
CM 430 Elite
Guys I think My Machine is unnecesarily heating up ...
After booting up when I open core temp (0% load)....
Lowest temp : 37 C
Highest temp : 61 C
Also When I run everst system stabilty test(For 10 mins !!!) ...
The CPU temp reaches around 72 C ..(THen I got scared and shut down my machine !!!)
The motherboard Temp : 71 C
Also under normal use ie: internet browsing (What I am seeing now ... The CPU temp is around 41 C)
Is there any serious problem ???
I have stock CPU cooler ...
Also My cabinet inside is a mess !!! No cable management of Any kind !!!!
I have 1 front intake fan(Cooler master) , 1 Side panel intake fan(Cooler Master), 1 Top exaust Fan (China Company) ....
DO I need More FAns ???
Plz HElp me ....
Thanx !!!!
vizkid2005 is offline   Reply With Quote
Old 30-11-2010, 04:49 PM   #2 (permalink)
Super Moderator
asingh's Avatar
Default Re: Machine Heating Up !!!!
Those are fine.
asingh is offline   Reply With Quote
Old 30-11-2010, 08:36 PM   #3 (permalink)
XLr8
arpanmukherjee1's Avatar
start to panic if cpu temp reaches ~98 C
i have same : max cpu temp at 100% load all cores = 80 C
for 23min 3ds max render
arpanmukherjee1 is offline   Reply With Quote
Old 30-11-2010, 08:46 PM   #4 (permalink)
Guys, which software or utility do you guys use to measure CPU temperatures?
AMD Athlon II X4 635 || Biostar MCP6P3 || 2GB Zion & 2GB Corsair DDR3 1333MHz || Seagate 1TB + Seagate 500GB || XFX HD4650 || FSP Saga II 500W || Zebronics Fantasy || LG W2043T
ssb1551 is offline   Reply With Quote
Old 30-11-2010, 09:07 PM   #5 (permalink)
core temp
It shows indivisual temps for each core ....
Old 30-11-2010, 09:10 PM   #6 (permalink)
Do I've to pay for "Core temp" or is it a freeware?
Old 30-11-2010, 09:11 PM   #7 (permalink)
CPUID HW monitor for AMD & Intel. for Intel only, its i think coretemp.
Old 30-11-2010, 09:15 PM   #8 (permalink)
Freeware !!!
Also do I need to invest in an aftermarket cooler ????
What are SYSTIN, CPUTIN, AUXTIN in Temperatures of Motherboard
& SYSFANIN, CPU FANIN0, AUXFANIN1 RPM`s of FANS ????
Like I didnt understand Which fan is which ???
CPUID Hardware Monitor is better than Coretemp .... It shows temps of mobo and gfx card too ...
Plz anyone help me with the SYSTIN CPUTIN etc meaning ???
Plz ....
Old 30-11-2010, 10:42 PM   #9 (permalink)
Super Moderator
asingh's Avatar
Intel : CoreTemp ; RealTEMP ; Everest Lavalys ; HW Monitor ; OCCT
AMD : CoreTemp ; Everest Lavalys ; HW Monitor ; OCCT
Old 07-12-2010, 04:35 PM   #10 (permalink)
Never give up!!
jerrin_ss5's Avatar
u can use speedfan software to measure various system temp.!
jerrin_ss5 is offline   Reply With Quote
Old 07-12-2010, 10:02 PM   #11 (permalink)
avichandana20000's Avatar
if you are using WINDOWS VISTA u can downld VISTA GADGET which will show temp used by each core.
NZXT PHANTOM WHITE|GA990XA UD3|955BE 3.6(O.C.ed)|MX-2|HYPER EVO|SAPPHIRE 6670 DDR5|DELL SP2309W|CORSAIR XMS 2X2GB 1333|450VX|SEAGATE 1TB|LOGITECH G110|APC 650 VA|
avichandana20000 is offline   Reply With Quote
Old 10-12-2010, 06:31 PM   #12 (permalink)
Treatment in progress...
mukherjee's Avatar
U have the CM 430 cabby right?
U cud invest in 120mm fan(s),and optimise them for exhaust or intake...
Experiment to find ur sweet spot.
Cable management also helps.
If possible,post pics of ur cabby...
Have a look here....
PC: Core i7 2600K||Z68V Pro||Noctua U12P SE2
Vengeance 1600Mhz 8GB||GTX560Ti HAWK
CM Elite 430||1TB+300GB
VX550||G110||G1 mouse||Razer Goliathus
Photography: Nikon D5100||Nikon 55-300 VRII
Canon Powershot SX220HS||Tamrac Velocity 9x
Audio Gear: Brainwavz M4||Meelec A151|| EP630
PX100 II||Fiio E5||AudioTechnica ATH-T500
mukherjee is offline   Reply With Quote
