22-11-2010, 07:35 PM
24GB of RAM not showing up. Only 16GB shown.
Hello everyone!
I bought 24GB of RAM for my computer and i can only see 16 GB. I did see 24GB for a day or two. But then it disappeared again. What can be the problem?
Motherboard: MSI Big Bang X-Power
Processor: Intel Core i7 980X
RAM: Corsair XMS3 1600 (4GBx6)
Any help regarding this would be appreciated!
Core i7 980X
X58A-UD-7
24GB XMS3 1600 MHz
Palit GTX580
Corsair HX1000
Cooler Master HAF 922
Cooler Master V8
Razer Mamba
Razer Lycosa Mirror
Dell UltraSharp U2410
Wacom Intuous 4 M
22-11-2010, 07:41 PM
Super Moderator
Re: 24GB of RAM not showing up. Only 16GB shown.
You on a 64BIT OS..?
22-11-2010, 07:42 PM
M3TAL H3AD M3
24GB or is it me only whose jaw just dropped down.
I spit Rainbows.
22-11-2010, 08:02 PM
The Assassin
^^ me too. Thats a killer config. Are you running a server on it nakulvit?
22-11-2010, 08:20 PM
^^Add 1 more to the list whose jaws dropped after seeing 24GB...and then the MoBo....and then again the CPU!!  ..Its a monstrous config!!
22-11-2010, 08:23 PM
my precious
Check your bios. And big woot for 24gb
I have 32 gb ram in my pc btw.
22-11-2010, 08:31 PM
^^  ..Dude you don't even have your PC with you!!Its way back at home!!
22-11-2010, 08:35 PM
PhotonAttack
first boot with each stick of ram alone and run memtest and see if all modules are ok.
if all ram sticks are fine and yet you dont see all the capacity try increasing the dram voltage a bit. what are the specs of your ram can you link to its spec page ?
_
In a time of universal deceit, telling the truth is a revolutionary act - George Orwell
|| तमसो मा ज्योतिर्गमय ||
22-11-2010, 10:01 PM
Point Blanc
do not worry list will go long of the people coming drooling around just hearing about it LOL
also people have already suggested what is needed to check. I am guessing one RAM already got caput hahahaaa
@asingh you also know it wont even show 16 GB on 32 bit
22-11-2010, 10:19 PM
Searching for Anti-Matter
clr CMOS and try again also BTW even 8GB of RAM is waste of money unless u running a supercomputer with teslas inside  but its gr8 for showoff , whats the speed and timing of ur rams ?
Q6600 @ 3.8Ghz , Sapphire HD6950 2GB @ 920/1370 , 4GB DDR2 Corsair DHX , Razor DeathAdder , Corsair HX 850 ... and what else ...
22-11-2010, 10:35 PM
well nakulvit what kinda work u do on ur "personal" super computer..???
23-11-2010, 06:31 AM
Hello again!
Thanks for the pretty much instant replies!
Yes. Windows 7 Ultimate x64
I think there must be a problem with the DIMM slots.
If i load a single stick into the DIMM 0, it won't boot.
Then putting 1 more into the DIMM 1 shows 4 GB.
Adding one more into DIMM2 shows 8GB
Adding into DIMM 3 has no effect and it shows 8GB
Adding into the DIMM 4 shows 12GB
Adding into DIMM 5 slot shows 16GB.
I guess there's something wrong with the DIMM 0 & DIMM3 slots.
HERE is the spec of my RAM:
Newegg.com - CORSAIR XMS 4GB 240-Pin DDR3 SDRAM DDR3 1600 Desktop Memory Model CMX4GX3M1A1600C9
For the rest of your queries, i'm a freelance post-producer for videos. So i do a lot of animation, rendering and editing.
Did i mention that i also have a GTX580? Two render nodes with AMD 1090T &12G? 22TB total storage across the entire setup??
Okay, now i'm just showing off. Please still help me!
Core i7 980X
X58A-UD-7
24GB XMS3 1600 MHz
Palit GTX580
Corsair HX1000
Cooler Master V8
Razer Mamba
Razer Lycosa Mirror
Wacom Intuous 4 M
23-11-2010, 06:59 AM
my precious
I thought you would mention something like quadro6000 which has 6gb ddr5 memory etc. Since that is the one suited for such a task. But gtx580?
23-11-2010, 07:09 AM
I actually was expecting that. Well there are a couple of reasons.
1. The actual GPU doesn't really speed up the render. It just makes viewing complex and more detailed models a lot faster and smoother. Rendering is almost entirely CPU based.
2. CUDA. Almost everything uses it. The newer render engines (VRay RT, iray), the Mercury Playback Engine in Premiere Pro CS5. Don't know about VRay 2.0.
Thhe GTX 580 has a lot more CUDA cores than the Quadro 6000 (Which costs about 10 times as much). So it was an easy choice for me.
Besides i do more video work and i need better performance in P.Pro. If i ever need to work on a complex model, i can always buy a quadro 4000 or so.
Getting back to my question.
I upped the DRAM voltage to the specified 1.65V. Still nothing.
Core i7 980X
X58A-UD-7
24GB XMS3 1600 MHz
Palit GTX580
Corsair HX1000
Cooler Master V8
Razer Mamba
Razer Lycosa Mirror
Wacom Intuous 4 M
23-11-2010, 04:17 PM
Point Blanc
you need your mobo checked DIMM slots not working properly is inference you got use that inference for RMA of motherboard whatever you do if the 2 DIMM slots have gone dead they wont come up alive.
23-11-2010, 05:02 PM
Super Moderator
Highly probable what Acewin, is saying is correct. You motherboard supports 800/1066/1333/1600/1800/2133 RAM speed, and your XMS3's are 1600 CL9s. You can do this...before sending for RMA -- figure out what to send for RMA.
1. Try all your DIMMs one-by-one on another DDR3 board. Just plug them in the first slot and see that the computer boots fine. Painful to do 6x times but will help. If you catch the bad DIMM here then the board is fine.
2. Try to load your board DIMM docks with the same color. Fill only BLUE or fill only BLACK and check.
Let us know.
23-11-2010, 05:30 PM
Fullbring
@nakulvit: on 24GB RAM one can play six games simultaneously...on Six monitors....hehe
23-11-2010, 07:02 PM
24gb Ram, i7 980x  ....if you don't mind me asking ...how much do you earn buddy?
Core 2 duo E4500 2.2gHz , ASUS P5GCMX , 3GB Transcend , Corsair VX 550w, MSI R5770 HAWK Edition 1GB, CM HAF-922, LG W2243T 21.5" LCD, I-Ball Baton
23-11-2010, 08:10 PM
#19 (permalink)
^+1......
23-11-2010, 08:44 PM
#20 (permalink)
you game on that setup? how many monitors are driven by the monster card?
23-11-2010, 10:04 PM
#21 (permalink)
Hello again!
2TB x 11 HDD?
Which cabinet?
24-11-2010, 12:51 AM
#22 (permalink)
Let us know.
THANKS A LOT GUYS! Turns out it was a faulty motherboard. There were some bent pins in the socket. The dealer gave me a UD7 instead and it works perfectly!
Originally Posted by avichandana20000
2TB x 11 HDD?
Which cabinet?
I have
1. 1xWorkstation of said config. (8.5 TB)
2. 2xRender Nodes with AMD 1090T's and 12Gigs of RAM (500GB each)
3. One storage server with 8.5TB
4. A couple of externals all amounting to 22TB
As of now i only have one. A Dell Ultrasharp U2410. Will upgrade to either a 27 or a 30 soon. It's relatively new.. The only game i've played so far is Assassin's Creed 2. Pretty smooth! What new games do you suggest?
Well, i just kinda started my own business. So i had to take a loan out for all of this. But the projected earnings will let me pay back the loan in less than a year. And maybe let me get a few upgrades as well.
Core i7 980X
X58A-UD-7
24GB XMS3 1600 MHz
Palit GTX580
Corsair HX1000
Cooler Master V8
Razer Mamba
Razer Lycosa Mirror
Wacom Intuous 4 M
24-11-2010, 11:38 AM
#23 (permalink)
Fullbring
@nakulvit: hey cud post ur entire config....in ur siggy......or here......
24-11-2010, 02:02 PM
#24 (permalink)
I think some pics would be good
Athlon II X4 635 @ 2.9Ghz || Biostar TA785G3 HD || G.skill 2X2Gb 1333Mhz DDR3 || WDC 500Gb Green || Corsair VX550W || CM Elite 330 || BenQ 2220HD || HTC Inspire 4G :))
24-11-2010, 03:05 PM
#25 (permalink)
or can try 2-3 monitor setup. that will be cheap (in your words) & will get more display area.
any game you like, just install, turn everything to max & enjoy. BTW when you brought that GTX580?
+1. want see such a setup. exterior as well as the internal parts.
24-11-2010, 03:49 PM
#26 (permalink)
+1
pics please.
24-11-2010, 04:17 PM
#27 (permalink)
Jai Suresh
24-11-2010, 05:32 PM
#28 (permalink)
I don't want IT
Never mind the problem - it was nice knowing you and the cheap stuff you use!
Who said hell doesn't exist?
I stay here!!
24-11-2010, 06:57 PM
#29 (permalink)
BIOS Terminator
u can easily run 10 OS's simultaneously!!!
28-11-2010, 09:43 PM
#30 (permalink)
Lol!! Sure! I am looking for a camera worthy of this mighty build. My E63 wouldn't be sufficient..
But yes. Pictures are very much in demand on Facebook too.
About a week back.
Core i7 980X
X58A-UD-7
24GB XMS3 1600 MHz
Palit GTX580
Corsair HX1000
Cooler Master V8
Razer Mamba
Razer Lycosa Mirror
Wacom Intuous 4 M
