Old 18-11-2010, 11:27 PM   #1 (permalink)
clerkman1612's Avatar
Talking plz help me?where my post gone?
Respected Dear Sir/Maam,
I made a post of buying related questions from a local shop. I m very surprised that where my latest post gone? I request you to plz tell me where is my last post. I want to know the advice given by Digit forums expert over it. I had talken about buying PC from SMC International (Nehru Place) in Delhi.
I would be highly grateful if u tell me.
Thanking you,
Sushant
clerkman1612 is offline
Old 18-11-2010, 11:29 PM   #2 (permalink)
Super Moderator
asingh's Avatar
Default Re: plz help me?where my post gone?
Here it is. Not sure, why the title has changed.
http://www.thinkdigit.com/forum/soft...ml#post1301103
asingh is offline
Old 18-11-2010, 11:37 PM   #3 (permalink)
harryneopotter's Avatar
The link is broken. Please Fix it !
Wats the Favourite Mathematical Function of DIGIT FORUM ????
Its "A SINE WAVE" constant
Y ??
They Both keep going "UP AND DOWN, UP AND DOWN............" !!!!!!!!
harryneopotter is offline
Old 18-11-2010, 11:37 PM   #4 (permalink)
Post Re: plz help me?where my post gone?
no Mr asingh,
my post was about buying related advice from SMC international(Nehru Place) Delhi.
yes Mr asingh,
You are right that was my post. But how do i fix it? I don't know the procedures. Thanks for helping me.
Last edited by clerkman1612; 18-11-2010 at 11:40 PM. Reason: Automerged Doublepost
Old 18-11-2010, 11:44 PM   #5 (permalink)
Super Moderator
asingh's Avatar
I think it is pointing to the correct place now..???
Ok, just realized it is a thead dead. Working on it.
Ico, has fixed it. Hope you can continue. Closing thread.
asingh is offline
