Old 18-11-2010, 11:12 PM   #1 (permalink)
Hmmmmm
Tenida's Avatar
Lightbulb Help regarding µTorrent
I am having windows 7 Ultimate 32 bit,Kaspersky internet security 2011.I am using µTorrent latest version to download whenever I am download something it give me a error [the requested operation cannot be performed on a file with user-mapped section open] and download is stopped.
How can I get rid of this error?Friends help me please.......
Tenida is offline   Reply With Quote
Old 19-11-2010, 01:01 AM   #2 (permalink)
Don Draper is coming back
vamsi_krishna's Avatar
Default Re: Help regarding µTorrent
I don't know if it helps, but try...
Go To Setting in KIS 2011
Select Application Control & Select Bit Torrent > U Torrent
Right Click on U torrent, Then To Application Rules
In Exclusion Tab > Tick on "Do Not Monitor Application Activity"
Source
I am MaxPayne. My Wife and Daughter were murdered.
vamsi_krishna is offline   Reply With Quote
Old 19-11-2010, 02:20 AM   #3 (permalink)
Hmmmmm
Tenida's Avatar
I have done that but no success.
Old 19-11-2010, 02:41 AM   #4 (permalink)
Then try Going into folder properties(Folder which is downloading) select Advanced and disable "Allow files in the folder have content indexed" Check box.
Old 19-11-2010, 02:52 AM   #5 (permalink)
Hmmmmm
Tenida's Avatar
ok..thanks..let see ....
I think the problem is solved by deleting old torrent file in Username>appData>Roaming>Utorrent.
