Old 17-11-2010, 06:55 PM   #1 (permalink)
Default Cooler Master 310 and 3 hard disks
I have a cooler master 310 using a 785Gm gigabyte board with its native 390W cooler master extreme PSU. I am currently running 2 hard disks SATA and 1 SATA Dvd writer
I want to install one more hard disk. Is it possible as I just cant find a slot in the cooler master cabinet. Also, it only has two SATA power connections. What to do?
Saurav2007 is offline   Reply With Quote
Old 17-11-2010, 08:06 PM   #2 (permalink)
Default Re: Cooler Master 310 and 3 hard disks
Oh bummer!!Well what you can do is convert 1 of the HDDs to an external one.
Oh & a sincere piece of advice - please change your PSU!Get Corsair CX400 or CX430.
ssb1551 is offline   Reply With Quote
Old 17-11-2010, 10:29 PM   #3 (permalink)
Ok, then I will get a CX430 which has 4 SATA connections
Is it available at any shop in Nehru Place/Delhi? What is the approximate cost
Old 17-11-2010, 10:35 PM   #4 (permalink)
harryneopotter's Avatar
Easily possible. Elite 310 has 6 Internal drive bays for Hard disks. So u can use 3 HDD very easily. As for the extra power connector needed, you can get a Molex to SATA power converter for any hardware shop for around 20 bucks.
Wats the Favourite Mathematical Function of DIGIT FORUM ????
Its "A SINE WAVE" constant
Y ??
They Both keep going "UP AND DOWN, UP AND DOWN............" !!!!!!!!
harryneopotter is offline   Reply With Quote
Old 18-11-2010, 02:55 AM   #5 (permalink)
Hmmmmm
Tenida's Avatar
Yes buy molex to sata power converter to use another HDD.
Tenida is offline   Reply With Quote
Old 28-11-2010, 01:55 AM   #6 (permalink)
I want to change the power supply after all as I am worried about the health of the PC. My system is 785GMUS2h Gigabyte MB and Phenom X2555 and running 3 hard disks with no graphics card. I wanted to get the Corsair 400/430 but what about FSP Saga II 500W. Should I go for the higher wattage?
Old 28-11-2010, 07:46 PM   #7 (permalink)
FSP Saga II 500W is also enough for your system if you cant find Corsair 400/450w PSU. And you dont need any higher wattage if you go with these reputed brands
Y ??
