Old 13-11-2010, 06:48 PM   #1 (permalink)
Default Multi-user Desktop Setup Suggestion !!
hey guys,
My current config is :
1. Core i7 920
2.Intel DX58SO
3. 6 Gb DDR3
4. ATI HD5770
5. 1 TB HDD
Well, i wanted to setup a multi user PC. . i have 2 monitor (dell 22" and a old CRT) k/b,mouse,spkrs.. So i was wondering it its possible to keep the same CPU for 2 computers. the other desktop would be in another room about 10m far. . . what would i need to do this kinda setup ?? i hope the config is sufficient for handling 2 users ..
Edit : I meant this kinda setup
Well i found some info regarding that in h**p://www.userful.com about connecting multiple PC's but it isn't clear regarding the display.. is there any cheaper way of connecting thru LAN and using the monitor, k/b,mouse, and speakers ??
Waiting for your advice guys..
abhadi is offline   Reply With Quote
Old 22-11-2010, 12:48 AM   #2 (permalink)
Default Re: Multi-user Desktop Setup Suggestion !!
I got my answer !!
Here's what u need
http://www.ncomputing.com/product-useries
The cheapest and best solution .. and its around 3-4k.. need to look around in chennai .. i hope i can find one easily
Old 22-11-2010, 02:25 AM   #3 (permalink)
Searching for Anti-Matter
Power_user_EX's Avatar
gr8....
Q6600 @ 3.8Ghz , Sapphire HD6950 2GB @ 920/1370 , 4GB DDR2 Corsair DHX , Razor DeathAdder , Corsair HX 850 ... and what else ...
Power_user_EX is offline   Reply With Quote
