Old 11-11-2010, 03:13 PM   #1 (permalink)
Default Suggest a good hybrid tv tuner for AMD PC.
System Config : AMD Phenom X6 1055 T Proccy
MSI GXM65 motherboard.
Kindly suggest a good hybrid tv tuner card for my PC which can record both analog (CABLE) and digital signals (DTH). The specified card model should be available in chennai.
Thanks.
bobgalee is offline   Reply With Quote
Old 11-11-2010, 06:37 PM   #2 (permalink)
vwad's Avatar
Location: Why ? Are you coming for dinner ? Pls. Don't.
Default Re: Suggest a good hybrid tv tuner for AMD PC.
Please mention your budget also.
Anyway, I will recommend getting a good TV Tuner from Leadtek.
For 4k budget
Theitdepot - Leadtek WinFast Hybrid TV Tuner (DTV2000 H Plus)
For 3.5k budget
Theitdepot - Leadtek WinFast Hybrid TV Tuner (DTV1800 H)
The above site is located in Chennai, so you can get delivery easily.
An Old Lady Died In Her Childhood.
vwad is offline   Reply With Quote
