Re: ink cartridge not recognised after refilling
Its is the first time you refilled that cartridge? If so, then you must reset the cartridge.
HP printers retain "memory" of the last two or three cartridges you use so that you won't refill it. Even if you refill, it identifies it from its memory and gives such error messages to coax you into buying a new original cartridge.
Anyways, resetting is easy and 5 minutes job. Google for it.
गीक होना माँगता
