Old 07-11-2010, 11:55 AM   #1 (permalink)
Siddarth Mallya
siddarthmallya's Avatar
Default ASrock ?
Is ASrock good brand ?
Is it a part of ASUS ?
How are their motherboards?
siddarthmallya is offline   Reply With Quote
Old 07-11-2010, 12:03 PM   #2 (permalink)
Don Draper is coming back
vamsi_krishna's Avatar
Default Re: ASrock ?
Yes ASRock is a subsidiary of Asus. Founded by some Asus co-founder.
Yes It has decent quality for it's price. Nearly five of my friends own this brand and they are running their rigs without any problem. It is recommend for building low budget PCs. And that's not to say that it is cheap. And, i must admit... they are feature rich too. You can get a mobo with wifi for just 2.8k or something(IIRC).. which wasn't there in my 6k intel board
I am MaxPayne. My Wife and Daughter were murdered.
vamsi_krishna is offline   Reply With Quote
Old 07-11-2010, 12:14 PM   #3 (permalink)
Siddarth Mallya
is this mobo good ? ASRock 880GM-LE
Old 07-11-2010, 12:28 PM   #4 (permalink)
Thats a DDR3 mobo.. so, you should upgrade your RAM, as well.
For it's price, the mobo is very good.
Old 07-11-2010, 12:35 PM   #5 (permalink)
Siddarth Mallya
k i just wanted to know that ASROCK mobos are good or not recommendable .
Old 07-11-2010, 12:40 PM   #6 (permalink)
^ Yes. For budget PCs, they are.
Old 07-11-2010, 04:42 PM   #7 (permalink)
Jaskanwar Singh's Avatar
also tell the indian price if you find that mobo.
