Old 05-11-2010, 09:37 PM   #1 (permalink)
Default Intel I5-750 pc getting frozen .. :(
One of my friend uses intel DP55WB board with core i5-750 proccy..
While working, frequent beeps are heared from the system unit and then the entire system gets frozen, after which restarting or switching off the ups is the only option .
he was using a local brand 400w psu and then upgraded to 600 cooler master extreme power series.
Re-installation of OS was done just a few days back and also no trace of any viruses..
help us guys..
Phenom II X6 1055T|Gigabyte 880GM-USB3|Transcend 4GB DDR3 1333MHz| Benq G2220HD|PowerColor Radeon HD5770|Seagate 500GB|Logitech MK250|CM Elite 310|Zebronics Pro 600w|Creative A100 2.1 speakers|LG DVD|
giprabu is offline   Reply With Quote
Old 05-11-2010, 10:43 PM   #2 (permalink)
Default Re: Intel I5-750 pc getting frozen .. :(
Remove the RAM/RAMs from the slot/s,clean 'em n put it bk again.C if it helps!!
ssb1551 is offline   Reply With Quote
Old 06-11-2010, 08:08 AM   #3 (permalink)
my precious
Gollum's Avatar
Check the temps of the system. It might be overheating.
Gollum is online now   Reply With Quote
Old 06-11-2010, 01:00 PM   #4 (permalink)
tempratures are quite normal under idle conditions dude...
the system is working fine from yesterday night.. it had been running for almost 4hrs from morning and the problem hasnt come yet..
No idea of what the problem is.. It may come again in future ..
Any way thanks for the help guys..
Old 06-11-2010, 07:12 PM   #5 (permalink)
avichandana20000's Avatar
The problem is that unfortunately u r having the worst psu ever made by CM. Do not buy any extreme series psu from CM. i have bought on in last january and after reading lots of TDF threads i came to understand that i am possessing the worst one. Then i change it to Corsair VX450. so never suggest CM EXTREME SERIES to anybody. pls change it asap.
avichandana20000 is offline   Reply With Quote
Old 06-11-2010, 08:17 PM   #6 (permalink)
^^OP doesn't hv CM extreme series..Its Zebronics Pro,tho not a very good 1!
Old 06-11-2010, 08:24 PM   #7 (permalink)
he was using a local brand 400w psu and then upgraded to 600 cooler master extreme power series..
where do you get that?
Old 06-11-2010, 10:37 PM   #8 (permalink)
Oh Crap!!I forgot it was his friend's PC tht had the problem.I saw his sig which has his system details!!
Well yeah u may b rite!!
