Old 05-11-2010, 04:51 AM   #1 (permalink)
Default DVD writer doesn't detect some CD's
Hi friends,
I am using LG dvd writter since 2 years. Since 1 month, it doesnt detect original CD's like antivirus CD's, CD's from magzines, motherboard CD etc., but it detects the CD's written on it or other writer
Dont know what is the problem. I tried to clean it through lens cleaner, but doesnt detects that also. It shows the drive, but empty.
Please help me. Thanks in advance:smile
gladiator55 is offline   Reply With Quote
Old 05-11-2010, 07:13 AM   #2 (permalink)
hansraj's Avatar
Default Re: DVD writer doesn't detect some CD's
The CD/DVD writers go bad this way only... it has been my experience. I dont think there is a proper solution to this problem. You may take it to the local workshop and they may be able to fix the problem but the problems reappear soon. IMO you should go for another drive now and they are not very costly either......
"An eye for an eye leaves the world blind." - Gandhi
Athlon II X 4 620 Quad Core, Gigabyte GA-MA 785 GPMT, G-Skill DDR3 1333 Mhz 2GB X 2, Seagate 1 TB + Seagate 80 GB, Win 7 Ultimate 64 Bit
hansraj is offline   Reply With Quote
