Old 31-10-2010, 12:53 AM   #1 (permalink)
Exclamation which motherboard ( AMD )
iam planing to buy very entry level AMD desktop pc which motherboard is best for AMD ( ASUS , MSI , gigabyte ) i want to Add graphic card also... later.... my budget is 10 to 15 ....please give ur suggestion
AMD Phenom II X2 555 ( 3.2 GHz ) + ASUS ATI Radeon HD 4350 1GB DDR2 + ASUS M4N68T-M V2 + DDR3 - 1333 4GB RAM + seagate 500 GB sata
savithk is offline   Reply With Quote
Old 31-10-2010, 02:01 AM   #2 (permalink)
Manchester United <3
Ishu Gupta's Avatar
Default Re: which motherboard ( AMD )
Budget is 10 to 15. Hundred or Thousands??
Also what processor?
Ishu Gupta is offline   Reply With Quote
Old 31-10-2010, 06:36 AM   #3 (permalink)
damnbadman666
damngoodman999's Avatar
If its 10K to 15K than ASUS CROSSHAIR IV FORMULA !
damngoodman999 is offline   Reply With Quote
Old 31-10-2010, 08:16 AM   #4 (permalink)
my precious
Gollum's Avatar
I think he meant that budget for the whole pc and not just for the mobo.
@savithk
Which cpu are you planning to buy. Without knowing that we cannot say much.
Gollum is online now   Reply With Quote
Old 31-10-2010, 09:30 AM   #5 (permalink)
Since its entry level I'm guessing Athlon II X2 or X3!!
ssb1551 is offline   Reply With Quote
Old 31-10-2010, 06:02 PM   #6 (permalink)
budget for the whole pc 10 to 12 Thousands
Old 31-10-2010, 09:21 PM   #7 (permalink)
Can u plz tell us which MoBo r u gonna use?
Old 01-11-2010, 02:54 AM   #8 (permalink)
Ishu Gupta's Avatar
@ssb1551
Thats what he is asking
Gigabyte GA-MA74GMT-S2 - Rs 2700
Old 01-11-2010, 03:38 PM   #9 (permalink)
pegasus's Avatar
ASUS M4A78LT-M LE - 2.9K approx iirc
(Socket AM3, HyperTransport 3.0, 760G, DVI port, EPU for power saving, 6x SATA ports, Anti-Surge protection, Express gate, ...)
ASUSTeK Computer Inc.
pegasus is offline   Reply With Quote
Old 01-11-2010, 08:38 PM   #10 (permalink)
Originally Posted by Ishu Gupta View Post
@ssb1551
Really really sorry man!!I meant which CPU.
Dunno wat was wrong wid me yest!!made couple of such mistakes!!Guess 1 of those days!!
Old 01-11-2010, 09:19 PM   #11 (permalink)
laborare est orare
Cilus's Avatar
Rather than whole PC type of thing, specify explicitly what are the items you need to purchase, motherboard, CPU, Ram, Graphics card, PSU, cabinet, everything. Then I think forum members will suggest you a better solution regarding the rig.
Phenom II X6 1090T@3.6GHz|8 GB RipjawX 1600 MHz|1+2TB Seagate + 1 TB WD Green 64MB Cache|Sabertooth 990FX|HD 6870CF|GT 240 1 GB GDDR5 PhysX|CM690II Advanced|G2220HD|TX850 V2|2 CM 1600RPM FAN|MX518|Razer Goliathus|Razer Arctosa|Corsair HS1A|APC1.1KVA
Cilus is offline   Reply With Quote
Old 02-11-2010, 07:35 PM   #12 (permalink)
i want to use..
should i go for ASUS M4A78LT-M LE
i need 2 GB RAM
Graphics card ( which model )
PSU
what total amount Rs-...?????
give me ur suggestion please
Old 02-11-2010, 08:10 PM   #13 (permalink)
Ishu Gupta's Avatar
How are you getting this in 10 to 12k??
Your Build
AMD Phenom II X2 555 @ 5K
should i go for ASUS M4A78LT-M LE @ 3k
i need 2 GB RAM @ 2k
PSU
Thats 10k already and you need GPU and PSU too.
My suggestion
AMD Athlon II X3 435 @ 3600
Gigabyte GA-880GM-UD2H @ 4500
Kingston Value RAM 2GB DDR3 1333MHz @ 1750
FSP Saga II 400W @ 2000
Total 11850
You didn't mention HD in your build. If needed
WD Caviar Blue 500GB @ 1850
Total 13700
Old 02-11-2010, 08:30 PM   #14 (permalink)
There is no way u can get Phenom II 555 n a good GPU with all the other stuff for 12k!!
Old 02-11-2010, 10:07 PM   #15 (permalink)
Wise Old Ghoul
Piyush's Avatar
@ishu
kingston 2gb ddr3 a@1.75k!!??!!
thats really awesome if its available
Steam:http://steamcommunity.com/id/alien007
"What kind of tomorrow should I dream about tonight"
--Get Backers
Piyush is offline   Reply With Quote
Old 02-11-2010, 10:12 PM   #16 (permalink)
Ishu Gupta's Avatar
@piyush
Yeah. Its value RAM but still.
Ram=>Deltapage.com
Old 02-11-2010, 11:12 PM   #17 (permalink)
AMD Phenom II X2 555 run very hot i want to CPU cooler also ( which model )....????
Old 02-11-2010, 11:17 PM   #18 (permalink)
Ishu Gupta's Avatar
Who says that it runs hot. You don't need a cooler.
Anyways a decent cooler will cost around Rs 1500.
Old 02-11-2010, 11:26 PM   #19 (permalink)
The Sorcerer's Avatar
The guy is also posting on chip so just saying the same thing as I said there:
There's a difference between warm and hot. Don't assume and speculate unecessarily. Stock cooler will suffice on stock settings. Since you are not bothered to answer anyone's reply in chip and digit, there's no point in advising you any further because its seems you're not interested.
Hardware BBQ
The Sorcerer is offline   Reply With Quote
Old 03-11-2010, 01:10 AM   #20 (permalink)
till you not unlock it (to quadcore), it should run cool. once unlock it may start problem. my friend unlocked his X2 555 to X4 B55 today & the initial temperature after some use jumped to 40degree.
Old 04-11-2010, 11:11 AM   #21 (permalink)
well iam planing for Overclocking AMD Phenom II X2 555
Old 04-11-2010, 11:23 AM   #22 (permalink)
my friend said that AMD get heated very fast so he prefers Intel at any cost
Is it true ???
With Regards
Jatin Jha
www.twitter.com/jatinjha
way2jatin is offline   Reply With Quote
Old 04-11-2010, 02:26 PM   #23 (permalink)
Ishu Gupta's Avatar
Is it true ???
No mate, not true. Look a few posts above.
Old 04-11-2010, 02:38 PM   #24 (permalink)
Is it true ???
can't believe ppl r still sayin this n then there r some of us who actually believe it!
Damn all these local retailers who shun AMD n ask ppl to get Intel!!:Cangry:..
Not takin anythin away from Intel.They r good too but AMD aint bad either!!
Old 04-11-2010, 05:59 PM   #25 (permalink)
my precious
Gollum's Avatar
For 10k you can only get a decent motherboard, cpu and ram. For psu and gpu you will need more. I'm currently searching for cpu, gpu and ram for 10k.
Old 05-11-2010, 07:59 PM   #26 (permalink)
thax for suggestion
